11-27-2015, 11:40 AM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Eibachs still the go to spring?
I've bee doing some research, and it sounds like the Eibachs were very popular as a replacement for when the springs break on the Z4.
For a non-autocrossed, non-tracked Z4M roadster, where I simply wanted to replace the stock springs to avoid future breakage, are the Eibachs still the go to spring -- knowing that it will also lower the ride height slightly -- or has anything better come along? I don't want a stiffer track suspension. Thanks! Salty |
11-27-2015, 12:46 PM | #2 | |
701
If you're at 40k or thereabouts the original OEM shocks are almost certainly toast. In that case I'd recommend going with H&R Coilovers, or replacing both springs and shocks. H&R may be the ticket you're looking for given the desired application (street, stock ride or better, lowering capability). |
11-28-2015, 10:18 PM | #3 | |
Rep 870
I had heard the H&R springs are a bit rough for street use. Are the coilovers good for street driving? Thanks for the info! |
11-29-2015, 07:48 PM | #4 | |
Rep 321
11-30-2015, 11:20 AM | #5 | ||
701
H&R Coilovers (new springs and paired new shocks) are considered to provide a better ride than stock (less harsh) as long as you don't lower too far. These are height adjustable, so you don't have to go for a big drop. More info below. I really recommend changing both springs and shocks given age/mileage of the car. I'd check the end links and top hat while your at it too. http://www.zpost.com/forums/showthread.php?t=620737 |
11-30-2015, 11:29 AM | #6 |
Rep 904
I was in the same position as you - I had a broken rear spring and was closing in on 60k miles. I decided to get new springs and shocks at the same time so I didn't have to do the work twice. I went with Eibach springs and Koni shocks because I didn't want a big drop and I wanted to retain a softer ride for street use. So far so good - my new setup actually feels more comfortable than my stock M sport suspension did on my 3.0i with the broken spring. The Koni's are adjustable so you can choose a softer setup if you want.
11-30-2015, 02:39 PM | #7 |
Rep 912
I'm still looking into options for the spring.
I'm now debating, KSport coils as I've seen a lot of posts (on other car forums) about H&R's blowing out. I've run B&G RS2 full coils in my jetta wit ha fairly aggressive setup and they lasted well but were very stiff. There are so many options on www.ECStuning.com for good prices I'm having a tough time to decide. But doing the springs and struts already get's you into the price of some basic coil over systems. |
11-30-2015, 03:24 PM | #8 | |
701
KW V3s usually get panned by the Z crowd as "too soft" even relative to stock. The other option out there some folks seem to like for street--at the lower end of the price scale--are the base version of Fortune Coilovers. These have bearing options and spring rate options too. I'm down to that or H&R for a suspension refresh for my wife's ///M that sees street duty only, but where she wants a firmer than stock set-up (spring rate options lean me towards Fortune). http://www.zpost.com/forums/showthread.php?t=821246 |
12-01-2015, 08:49 AM | #9 |
Rep 912
Anyone have any luck with Megan coils?
There seems to be many options but no consistent winner for price, reliability and performance. List of Brands I've come across:
12-01-2015, 10:05 AM | #10 |
Rep 2,704
You get what you pay for when it comes to coil overs IMO.
Can't go wrong with a good dropped coil and shock/strut combo. Think about it, how many times are you going to "adjust" your ride height?
12-01-2015, 01:28 PM | #12 |
Rep 904
It's not how many times you adjust your ride height as much as it is getting it to the right height. With coilovers you get a bigger range of ride heights and once you get the right setting you can leave it. Also as 3GFX noted you can change the height based on the wheels you have on the car. If you daily drive it in the winter (it does snow in the mountains in NC, but I'm not sure where saltyNC lives) then you can raise the height to the max, then drop it down again in the summer. These considerations don't matter to most people, but they're worth mentioning in case any of them apply to the OP.
12-01-2015, 02:05 PM | #13 | |
Rep 2,704
Now if you are just after the slammed look fill your boots.
12-02-2015, 08:07 AM | #14 |
Rep 870
Thanks everyone for the info.
02-28-2016, 09:01 PM | #16 |
Rep 143
My 2006 MR has 40K mikes. Anyone have experience auto Xing on the H&R coilovers? I'm not looking to go to nationals, just a good blend of good street ride and "competent " autocross capabilities.
02-28-2016, 10:40 PM | #17 |
1621
Rep 4,294
the H&R spring combo with Billstein HD shocks is a great combo, ride is better than stock and you get a little bit lower..
Powered by |
02-29-2016, 09:59 AM | #18 | |
Rep 143
Are the Stock springs on the MR linear or progressive? Last edited by Bossdog; 02-29-2016 at 10:45 AM.. |
02-29-2016, 07:39 PM | #19 |
1621
Rep 4,294
not sure, my car had close to 130k miles on it when i re-newed the suspension, if it was the original, it was pretty shagged, 2 rear struts leaking slightly and a very annoyingly squeaking rear spring.
after the swap, my car was transformed, that said, i did replace pretty much every rubber bushing under the car. but yeah the car was like it was on rails, very very, very little to no body roll, i remember quantifying it versus my old Z3, which was like a wet blanket compared to the FOUR after the suspension swap. I can't comment on versus stock as my car had a lot of miles on it when i got it, and lets just say that it did make night and day difference after the swap. Nfi if the stock springs are linear or progressive.
Powered by |
05-10-2016, 09:29 PM | #21 |
Daily driver/Weekend mechanic
Rep 48
Drives: '06 Z4 3.0i Roadster
Nope, standard non-m springs have a linear compression rate. Eibach springs have a progressive compression rate. It took about a 500 miles before my Eibachs were worn in.
I paired them with koni sports. Together, the ride is really good for street driving, maybe a bit soft. I have the fronts adjusted to firm. My only regret is that I left the rears at medium. They should also be firm. As it is, potholes aren't no big thing and the car sits down nicely at 90 on the freeway and doesn't budge. Last edited by Forbes; 05-10-2016 at 09:36 PM.. |
05-11-2016, 12:09 AM | #22 |
1621
Rep 4,294
I just wanna chime in that if your just going to replace the springs (H&R or Eibach), you'll probably get a harsher ride than stock as the stock struts are valved for a certain ride height, run the car lower and it will be harsher.. not only that, but you'll wear out the stock strut quicker than when using the correct stock spring with the stock strut.
Powered by |
