01-22-2016, 07:25 PM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Burnish Parking Brake
I searched but couldn't find anything on this. BMW service recommends burnishing the parking brake on some service intervals. Are they talking about applying the parking brake gently while the car is in motion?
And on a similar line of thought, do most of you grease your wheel center bearing? Thanks! Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 01-23-2016 at 07:09 AM.. |
01-23-2016, 08:23 AM | #2 |
Rep 870
BMW TIS Procedure
I found this in the BMW TIS for the e85 M roadster for burnishing the parking brake as recommended during Inspection 1/2. So, pretty much as thought, you apply the parking brake gently while the car is in motion for a short duration.
