      06-16-2009, 10:49 PM   #1
Jeffrimerman
Drives: BMW R50
My light is blinking now that I got new rear tires...why?
I just changed my rear tires since my old ones are almost bald. Now when I take turns and a good speed my light(A with arrow point around) blinks. I can feel my abs pulsating. It didn't do that before. I'm wondering if my tires gripped so good before that it didn't trigger the system to activate or is it because it was slipping before and now it is gripping better so that system is detecting a difference in the left and right rear tire and that is causing it. I'm just curious why now and not before.
      06-17-2009, 09:48 PM   #2
mpower03
Drives: 08 z4 M Coupe
sounds like your traction control light..
does it look like this?
http://lh5.ggpht.com/_x6-ZV2czdq0/SF...Y/CIMG7966.JPG
      06-17-2009, 09:52 PM   #3
Jeffrimerman
Drives: BMW R50
hmmm
The link doesn't seem to work. Yeah I think it is my traction control light. I gonna guess it is registering that I am slipping so maybe the new tires need to break in or maybe they just don't grip that good. They put the tires on with 38 psi, so maybe that is too much. I have 235 35 19s so I shouldn't be slipping that much.
      06-17-2009, 10:02 PM   #4
mpower03
what tires did you change to? did you change any sizes? 38 psi is a lot and as the tires got hotter the psi rises so your around 40 psi hot. i would lower that a little. it could need to be broken in.
      06-17-2009, 10:13 PM   #5
Jeffrimerman
Drives: BMW R50
ok good idea. I will lower them. Is 34 psi about right. I think that is closer to what I had it at before.
      06-17-2009, 10:26 PM   #6
VitaminT
Drives: 2006 M Roadster
I had a set of Michelin PilotExalto summers on another car of mine and they took about 500 miles until I felt confident with them. I haven't noticed this with other tires including a set of new PS2s. Both were from tirerack.
I suppose the traction control could be acting up if you went to some harder, higher tread wear tires that aren't quite as grippy.
      06-17-2009, 10:26 PM   #7
mpower03
im running about 30/31 up front and 33/34 in the back
      06-17-2009, 10:27 PM   #8
mpower03
lower psi = more grip
      06-17-2009, 10:28 PM   #9
mpower03
what kind of tires did you change to? Softer compound or harder compound or the same?
      06-17-2009, 10:38 PM   #10
Jeffrimerman
Drives: BMW R50
Ok good. I just lowered the pressure to 33 on the left rear because it was higher than the right rear for some reason. I just got them a few days ago so it will probably take another week of cornering to break it in. Thanks everyone. Oh yeah, I got some tires called Wanli. I'm sure they are probably not the best=/.
      06-17-2009, 11:16 PM   #11
mpower03
doesnt matter on brand. i got generals on mine. nothing special here. the lowered psi and break in should help. good luck
