      05-20-2012, 04:12 PM   #23
rsutoratosu
Drives: Z4 3.0i
Im looking to pick this up also, any DRL functions on it ?
-Roranji
      05-20-2012, 04:43 PM   #24
fercho
fercho's Avatar
Drives: 2005 z4 2.5
no I tried to activate that on our cars and I don't see the option for DRL
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
      05-20-2012, 10:48 PM   #25
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm pretty sure Progman will let you turn the halos on as running lights, but that's about it.
Don't think you can select fogs or anything.
This thread says DIS will do it, also.
      03-13-2013, 12:51 AM   #26
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
I just bought this as well. Are you still liking it? Will be looking forward to the install.
      03-13-2013, 12:55 AM   #27
StickMon
StickMon's Avatar
Drives: 2006 MR
Works as advertized. DIS will give you more accurate info on your O2 sensor problem than a generic OBD-II scanner.
      03-13-2013, 01:09 AM   #28
Steenos
2007 M Coupe  [0.00]
Stickmon I may contact you during install but I'm pretty computer savvy so I hope the install won't be bad.
      03-13-2013, 11:30 AM   #29
StickMon
StickMon's Avatar
Drives: 2006 MR
See posts 12 and 15 in this thread for the couple of gotchas I ran into.
      03-23-2013, 10:11 PM   #30
Steenos
2007 M Coupe  [0.00]
Hey stickmon, I've got al the software extracted but I'm trying to get the USB port installed. I changed the USB Serial port to Com 1 but I still get an error "This device cannot start (code 10)" Any ideas?
      03-23-2013, 11:17 PM   #31
StickMon
StickMon's Avatar
Drives: 2006 MR
Is it set for 9600, 8, N, 1?
I didn't use the supplied USB serial driver. I already had a USB-serial cable and driver for my Bearcat scanner, so when I plugged in the ODB cable it worked right away.
Try a different com port? I think the com port is the first line in obd.ini:
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
      03-24-2013, 12:39 AM   #32
Steenos
2007 M Coupe  [0.00]
yup stickmon thats exactly how i have it setup. this may be a stupid question but do i actually have to have the cable hooked up to the car or can i just have the cable plugged into USB?
      03-24-2013, 06:26 PM   #33
Steenos
2007 M Coupe  [0.00]
So I think I found my problem. I'm running windows 7. Installed XP and trying to reload the software.
      03-25-2013, 01:16 AM   #34
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm running on Win7 64-bit.
Many things will work, but not NCS Expert.
INPA, Progman/SSS, and DIS work.
I got NCS to run in an XP Virtual Machine, but it can't find the serial port.
Too many layers.
I have to buy the wife a new laptop one of these days so I can take her current XP one and make it a dedicated diag laptop.
According to Google, Code 10 is a driver issue.
      03-25-2013, 02:01 AM   #35
Shipkiller
Shipkiller's Avatar
Drives: Me
Just make sure the com port is set to the same number in XP as it is in the native OS.
XP Virtual Machine is very slow. If you can, use a VMWare machine. I KNOW that works.
      03-25-2013, 10:00 AM   #36
Steenos
2007 M Coupe  [0.00]
I wonder if Parallels is my problem. Maybe I should switch to VMWare. I'm gonna try and do a little bit more configuring to see if I can get it to work with what I've got.
      03-25-2013, 11:14 AM   #37
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Hurry up and get it working so you can reset my airbag light
      03-25-2013, 06:53 PM   #38
Steenos
2007 M Coupe  [0.00]
This driver issue is blowing my mind right now. Installed a VM of Windows XP. Finally got the hard drive space worked out where I could get the software on. Followed the video and the device manager shows that the USB Serial Port (Com1) is connected.
When I go to the software launcher I still get the error "Diagnostic Cable Drivers have not been detected"
I just don't understand how it can be showing as working in the device manager but not working whenever I click the software launcher. I did follow the video on how to install the drivers.
      03-25-2013, 07:50 PM   #39
StickMon
StickMon's Avatar
Drives: 2006 MR
Are you doing this on a Mac?
I can't remember the exact error I had, but I didn't get NCSExpert to find the cable in "Windows on Windows", running XP in a VM under Win7. I'll admit I didn't try very hard. My ADD kicked in.
I ran INPA/Progman/DIS native in Win7 (well Progman and DIS in the supplied hacked VMWare) without problem.
I was going to suggest uninstalling the driver that came with it, disconnecting it, plugging it back in and see if Windows would detect new hardware and find a driver in the Microsoft database.
The cable would appear to be pretty generic, since I used it successfully with a driver that came from and entirely different USB to RS232 cable.
      03-25-2013, 08:02 PM   #40
Steenos
2007 M Coupe  [0.00]
Yeah on a brand new macbook pro with Parallels desktop 8 and winxp
      03-25-2013, 08:11 PM   #41
Shipkiller
Shipkiller's Avatar
Drives: Me
Have the cable connected to the USB port when you start to install the software, not just the driver. Also, physically label the USB port 'BMW' or some such thing so you don't forget which port is now locked to the BMW software. This is the only physical USB port that will now work with the cable now.
Go to device manager and make sure the USB driver for the cable is set to the same COM port as the OS and VM. Very important.
Before I bought the BMTechinc package, I did a full install on Win7 (64) and everything works except NCSExpert, as expected. Then did another full install under XP in the VM. Now it ALL works under XP in the VM.
      03-25-2013, 08:21 PM   #42
Steenos
2007 M Coupe  [0.00]
Ship killer let me ask you this just to verify we're on the same page. I extracted the two files. Installed the drivers for the usb, and then hit the launcher icon and thats when I get the errors. Just making sure those are the basic steps. I haven't installed this kind of software in a long time so please forgive me.
      03-25-2013, 08:48 PM   #43
Shipkiller
Shipkiller's Avatar
Drives: Me
Your installation is different than the ones I had downloaded off of the internet.
There seems to be several different installs that people have come up with. That's the reason I like the BMTechnic package. It just works. Eight clicks and you are done. Of course, if you are running on a MAC, then all bets are off.
      03-26-2013, 11:31 AM   #44
Steenos
2007 M Coupe  [0.00]
Making Progress!
