      03-16-2022, 05:01 PM   #1
g59tyler
Drives: BMW Z4
Headlight front turn signal/side marker bulb out.
So my front turn signal/side marker bulbs on both sides are out. I’ve tried new bulbs, I’ve flipped bulbs back and forth and nothing. Is there a relay to this bulb?
      03-17-2022, 11:15 AM   #2
wdb
dances with roads
wdb's Avatar
4761
How's the wiring? The insulation on the wires in my Z headlights is falling apart. You might have a short or possibly even an open connection. Also the plastic bulb holder for one of my turn signal bulbs failed. Drove me nuts until I just decided to replace the darn thing and discovered it had gone bad.
      03-17-2022, 10:21 PM   #3
g59tyler
Drives: BMW Z4
Insulation is crumbling but I've pulled the headlight out and rewrapped as much as I could. I haven't hit it with a voltage meter yet but I need to, but I've tried cleaning contacts and stuff but I believe both went out at the same time so thats why I was thinking it might be a relay.
      04-03-2022, 12:27 PM   #4
CivVbmw
2009
Drives: M2&M5
You need to do something to that buddy…
