      05-27-2018, 04:08 PM   #1
JeroenS
Netherlands
Drives: BMW Z4 E85
Xmas tree of warning lights after dead battery
Hi, i’m hoping someone recognizes my problem and has some suggestions.
I have a z4 E85 and the battery died after being outside and not driving it during the winter months. I tried charging but would not start and a bunch of warning lights so decided to (try and) replace the battery.
The car does start now (immediately without hesitation) but I now get a Xmas tree of blinking warning lights (see attached images). Things like power steering, automatic gearbox, sometimes oil, temperature needle moving up and down etc etc.
I tried disconnecting the minus for an hour (as someone suggested another user with issues) but this did not help.
Anything I can do/try or of to the dealer (and big bill again)?
Thanks,
Jeroen
      05-29-2018, 07:37 PM   #2
JeroenS
Netherlands
Drives: BMW Z4 E85
Any suggestions. Appreciate the help...
      05-29-2018, 09:02 PM   #3
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Check for trouble codes and see if you have a communication code with the ICP - instrument control panel. It’s possible your cluster is out, might be a good place to start anyway.
      05-30-2018, 09:37 PM   #4
Cyclops
Cyclops's Avatar
did you check your fuses? maybe you blew something when charging or reconnecting the battery.
- Instagram ->@e91kiter
      05-31-2018, 06:31 AM   #5
JeroenS
Netherlands
Drives: BMW Z4 E85
Thanks Iongress and Cyclops. I've ordered a code reader and will check the fuses and report back. Appreciate the help
      06-05-2018, 06:45 AM   #6
JeroenS
Netherlands
Drives: BMW Z4 E85
I checked the battery power and all the fuses in the glovebox compartment and these are all okay.
OBD read-out gave a U3F00 once and a while, but can not find much about this online.
Any thoughts?
      06-06-2018, 03:04 PM   #7
rsutoratosu
Drives: Z4 3.0i
The 3 in the code is misfire..
I would check spark plugs, is idle okay or rough ?
-Roranji
      06-06-2018, 03:32 PM   #8
longress
longress's Avatar
Any thoughts?
That’s not a code i’m familiar with and I don’t believe it’s a misfire (that’s not your problem anyway) because those codes begin with P0300.
What kind of scan tool did you get?
There’s only one screw that holds in the cluster, you might just try pulling it out and reseating the connection.
      06-06-2018, 05:38 PM   #9
JeroenS
Netherlands
Drives: BMW Z4 E85
I tried a few... on android and iPhone... Torque, car scanner, fastlink.
However I read on another forum a reply from a BMW mechanic that this is a general code for vendor specific codes, and you need a reader that understand the BMW codes.
So I have a Carly on the way, which supposed to do that? (sorry new to this)
      06-06-2018, 05:42 PM   #10
JeroenS
Netherlands
Drives: BMW Z4 E85
The cluster is the dashboard/instrument cluster (i guess you call it in english) I presume?
Will read up on this and try and figure it out
Edit: found this, so seems clear: https://www.pelicanparts.com/techart...eplacement.htm
Thanks
      06-16-2018, 05:14 AM   #11
JeroenS
Netherlands
Drives: BMW Z4 E85
Unhappy Fault Codes Results
I finally received my reader which supports BMW Codes (Carly).
There are a bunch of errors, hope they make sense to someone...
(smart than me on these things)
Engine / Motor
Fault Code: 002DCC
Fault Explanation:News of the ASC / DSC missing, ASC 1
Fault Code: 002DCD
Fault Explanation:News of the ASC / DSC missing ASC 3
Fault Code: 002DCE
Fault Explanation:News of the ASC / DSC missing ASC 4
Fault Code: 00CD87
Fault Explanation:PT-CAN communication error
Fault Code: 002DD2
Fault Explanation:News of the LWS-control device is missing, LWS
Instrument cluster / Kombiinstrument
Fault Code: 0000F4
Fault Explanation::none CAN ID / CAN bus Error 244 / CAN: No ID -
No CAN signal for 1500ms and bus is not off
Fault Code: 0000F9
Fault Explanation::none CAN ID DMEL4 / none CAN ID ASC3
Fault Code: 0000FA
Fault Explanation::none CAN ID EML1 / none CAN ID EPS1
Fault Code: 0000F5
Fault Explanation::CAN: No ASC1 - No ABS report for 1500 ms / none CAN ID ASC1
Fault Code: 0000FB
Fault Explanation::CAN bus Error 251 / none CAN ID EGS1 / CAN: No EGS1 - No telegram received from ATCU for 1500 ms
Aircondition / Klimaanlage
Fault Code: 000034
Fault Explanation::Energy-saving mode is activated / K-bus velocity / Heat exchanger target temperature Links
Additional heater / Zusatzheizung
Fault Code: 0000DA
Fault Explanation::Vorkatsonde 1 signal swing / CDKCHDEV - CAN timeout HDEV / signal KVA2 / CAN module warning level reached / FS backrest head: blocking front / internal index 233
HiFi
Fault Code: 00611E
Fault Explanation::Error Code 18: vehicle speed
Fault Code: 00611B
Fault Explanation::Error code 15: steering angle
Fault Code: 00D6FE
Fault Explanation::Error code 32: day / night switch signal Fault Code: 00612A
Fault Explanation::Error code 30: Mileage / error 30
Gateway /ZKE
Fault Code: 00000D
Fault Explanation::Windows: interruption Einklemmschutzleiste Fahrertuer / Internal error in the basic module VI: Relay window motor rear door links errors / DRIVER RELAY NO FAULT / BT: Physical or open circuit / Windows: interruption Einklemmschutzleiste or de- normalization / error EKS Electronic Fahrertuer
Fault Code: 00000E
Fault Explanation::COMMON. RELAY NO FAULT / HK: Physical or short circuit to U-Batt / Windows: interruption Einklemmschutzleiste or de- normalization / error EKS Electronic Beifahrertuer / Windows: interruption Einklemmschutzleiste Beifahrertuer
      06-16-2018, 09:30 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
It has a memory of everything that's happened to it since it was last reset.
You need to clear these and then see what comes back.
      06-17-2018, 04:20 AM   #13
JeroenS
Netherlands
Drives: BMW Z4 E85
Thanks. I did do a clear with Carly and this is the report after the clear (before there were 2-3 more failures), sorry forgot to add that.
So either the clear failed (any way to check) or (most likely) these are all current failures..
      07-16-2018, 09:10 AM   #14
JeroenS
Netherlands
Drives: BMW Z4 E85
Well had no choice but to bring it to the dealer. For the benefit of others below a summery of the damage. The main cause was a problem with the DSC unit.
Total costs € 2.190
      07-17-2018, 08:52 AM   #15
longress
longress's Avatar
Total costs € 2.190
That's tough news but thanks for coming back and sharing the solution!
      01-20-2019, 09:15 PM   #16
TXBMRMAN19
Drives: 2004 Z4 3.0
I had the same issue on my 335i when my battery died. Like your's, my dash lights also lit up like a xmas tree and my windshield whipper would turn on and all power to the different systems like power steering , pump, etc would turn off. I plugged in my Carly scanner and all kinds of code come on. To make a long story short, I troubleshoot it and it was a bad alternator. I replaced it, cleared the codes and no more issues.
