      03-18-2021, 07:41 PM   #1
stephenkirsh
Drives: Z4M, E46 ZHP, E46 ZSP, NA MX5
Drive cycles needed to set emission SMOG readiness check - hot O2 check
I cannot get the final SMOG readiness check to swap over to "ready." It's the "H O2" or O2 heater (or hot O2?). I've done 3 different drives for a combined 150 miles or so.
I've recently swapped headers and have had no codes or other issues. All of the others are set to "ready."
Any ideas?
His: 07 Z4 M Coupe - 05 330i ZHP
Hers: 04 330i ZSP
Sold: 04 325i M56 SULEV, 95 NA Miata
      03-21-2021, 08:40 PM   #2
Reborn_
Drives: 2007 BMW Z4MC
This is my guess/ intuition. More drives (they can be short distance) are needed. I say this because oxygen sensor heaters are all about getting the sensors up to temp quickly when the engine/exhaust stream is not hot enough.
      03-22-2021, 06:54 PM   #3
stephenkirsh
I got it to set to "ready" today.
Somewhere else somebody said to follow these steps:
  • Turn on the car from cold
  • Let the idle come down to normal, then turn on all electronics:
  • A/C, seat heaters, radio, defroster
  • Idle for 2.5 minutes
  • Then drive for 10-15 minutes
I followed that precisely, except for the 10-15 minute part; it was closer to 60-70 minutes. One note: I didn't turn on any interior or exterior lights. Also, a lot of these guides say you need 35-85% fuel capacity. That might be for some test, but I started this one at 95+%.
Reborn_, after reading a few items this weekend, I agree with your statement. I think the first bit of my process is what worked. Thanks
Hers: 04 330i ZSP
Reborn_298.00
      03-25-2021, 12:47 PM   #4
F360C
Drives: E86 S54
What headers did you swap to? 02 sensors new or swapped over? If the exhaust set up is different then OEM where are your sensors located?
07 Z4 M Coupe AW/IR
      03-25-2021, 12:56 PM   #5
stephenkirsh
I removed catless headers and put the original OEM ones on. Everything on the car is currently stock.
Hers: 04 330i ZSP
