      04-25-2015, 07:52 AM   #1
lucam
lucam's Avatar
Drives: Z4 3.0si
Selling a 2006 3.0si
I became a grandfather lately and need a different car, have a black/black roadster 3.0si with sports package, 6 speed, 30K miles, 4 Michelin Pilot tires in perfect condition in case someone is interested.
      04-25-2015, 08:07 AM   #2
WestCDA
Drives: 2006 Z4R 3.0si
Congratulations! ��
The car looks nice - but you need to post an ad in the classified section where it belongs, with a price on it. More pictures and details will also help you sell it a lot faster. Check out some of the other ads. Good luck, Gramps..
      04-25-2015, 08:13 AM   #3
lucam
lucam's Avatar
Drives: Z4 3.0si
Thanks, will follow your advice
      04-25-2015, 09:59 AM   #4
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Gramps ...
Powered by
      04-25-2015, 10:34 AM   #5
cooticooti16
cooticooti16's Avatar
44
Drives: Lexus
I just became a father, so maybe this car will be a great relief from the minivan and CUV life!
Is the steering that much disconnected from the hydraulic setup in the Z4M?
R.
      04-26-2015, 09:43 PM   #6
chickdr
Drives: 2006 M Roadster
R.
Personally, it was night and day for me. I wouldn't have bought an si after driving the M based on the steering feel alone. The motor in the si is fine and if I could have had the M's steering rack I would have done it.
      04-26-2015, 10:00 PM   #7
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
My brother has the electric steering in his X3, strange at first, but i am sure you could get used to it. but thats just my crappy opinion..
Powered by
      04-26-2015, 10:19 PM   #8
itdnwiwbp
Drives: 330iZHP
Ditto. Had an si coupe before the M. Also became a dad on Tuesday so congrats from a fellow new dad cooticooti16!
Edit for Huz-z: Yes, it had RFTs when I purchased the car but got non-RFTs when I upgraded the wheels. Definitely a huge improvement.
      04-27-2015, 06:54 AM   #9
Huz-Z
Huz-Z's Avatar
It would be helpful if the folks commenting on steering could note whether or not the SI that they drove had the original run flat tires or not. I say that because the SI's steering is vastly improved by replacing the run flats with conventional tires. Virtually every Z4 owner here (other than those with M's which have conventional tires anyway) have done that and been very pleased with the results.
The steering of an SI with conventional tires will not be as nice as an M - no argument there. But I think most would agree that its a big improvement and IMHO, quite acceptable.
Huz-Z
      04-27-2015, 08:10 AM   #10
chickdr
As the two I drove were both dealer cars(one new and one off lease) I assume they had RFT's. I am sure that does make a difference, but it is more than that. I had an S2000 prior to the M Roadster and it also had electric steering. It wasn't bad, but still lacked the feel the hydraulic system gives you. I suspect the new electric steering Boxsters have the same issue compared to the older cars.
      04-27-2015, 08:53 AM   #11
BGR
Drives: C7 GS 7MT; e90 M3 6MT
I'm going to start by saying I'm a steering feel snob, and have owned a number of performance oriented cars to make this comparison, including a 2010 135i which is probably closest in size to the Z (and an S2k, e39 M5, e30 iS, and MKIV GTI).
The first thing I did when getting my Z4 Coupe 3.0si was swap out the wheels with Breytons that had non-RFT extreme performance summer tires.
The steering is well weighted and precise, but definitely doesn't provide the level of feedback as a hydraulic rack. That said, I would never NOT buy this car again because of the steering. For me it is almost a non-issue (I can't believe I'm saying that...). Sure, the Z4M is probably a bit better, but when I'm on the track and push a little too much in the corner to induce understeer, I can actually feel the wheel getting a bit lighter as the front wheels lose grip. This is not something common to electric power steering.
NOTE: I do have suspension and bushing upgrades, which probably helps contribute to the better feel.
