      07-12-2011, 09:58 AM   #1
baege
Drives: 2022 Cayman GTS 4.0 6MT
Approximate cost of Inspection I for 2007 3.0Si?
tried this in the Canada forum but got no love
indicator says another 6500 km (4000 miles) until its needed.
Anyone had inspection I done at their own cost? If so what did you pay for it?
Cheers
      07-12-2011, 11:26 AM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Doesn't the manual show what's due for replacement in Inspection I (never checked mine, I looked for the M checklist here)? In any case, here's a link to the schedule.
Try this thread. You'll have to convert from pounds to Canadian dollars, but it should give you an idea of what's entained in Inspection I.
Looks like it would be the following, but please check the PDF schedule I provided since I didn't double check my work....
Brake Fluid change ~20 dollars
Brake pads (if indicated) 80-120 from Zeckhausen or Turner (BMW OEM are twice that amount
Oil Filter ~13 dollars
Oil ~60 dollars?
Wiper blades (BMW original) 60 dollars (I'd just get some cheaper ones from the local auto store)
Air Filter 40 dollars
Microfilter (cabin air filter) 50?
So around ~300 - ~325 in US dollars in parts. They'd probably charge 2-3 hours labor, so factor in whatever the going rate is for that.
Look here for estimated prices
All those are parts prices and labor isn't factored in. It's a pretty easy DIY IMO.
      07-12-2011, 12:17 PM   #3
baege
Oil ~60 dollars?
Thanks so much for the information. Most of that has been done on my car with regular service. The brakes were flushed and pads checked every 2 years (the last time being this last May), the oil service was done annually and included replacing the incabin microfilter. Looks like I'll be essentially asking for an air filter change, brake pad check, and oil service next year when I will have probably travelled the 6500 km that remains.
