07-21-2010, 04:10 PM | #1 |
Rep 12,565
Dealer Replaced Clutch - Doesn't Feel the Same, Any Input?
So I dropped off my car at the dealer last week for 30k / Inspection I, clutch issues (throw-out bearing – rattling noise), and the n52 chatter issue (related to lifters). Surprisingly the dealer was great about looking into everything and confirmed all my complaints. They installed new lifters and replaced the clutch. The actual invoice stated:
Throw out bearing is excessively worn and has damaged clutch pressure plate. Clutch measures at 5.8mm. Throw out bearing / pressure plate are faulty. Replaced clutch / throw out bearing and clutch pressure plate. So after I pick up the car, the first thing I immediately notice is the clutch feels so much “lighter” and “softer.” It takes minimal effort to fully depress the clutch. On the original clutch, you had to actually push your foot down to fight the clutch but at least you could then feel the engagement point much easier. It just had a sportier feel to it but now the clutch feels just like the 335i I had as a loaner a while back, it’s more forgiving and it’s harder to spot where the engagement point is. I know being a new clutch, the engagement point would take getting used to but the difference is night and day. So my questions are: 1. Was that raw clutch feeling I was used to before a result of faulty clutch I had all this time? 2. Is this the way the Z4 should drive from factory? Or did they replace the clutch with newer components, ie from the e90 and this is why it drives like the 335i I had? 3. And would the modified CDV I had installed previously still be there or would they have replaced that as well? On a positive note, every shift is smoother (especially downshifts), there’s no rattle at idle/neutral and shifts in general just seem easier (less effort on my part to have to manage the timing – but again could be result of clutch feeling so “forgiving”. Hope this post makes sense, any input is appreciated. Last edited by 3002 tii; 07-21-2010 at 04:18 PM.. |
07-22-2010, 06:34 AM | #2 | |
Rep 1,991
07-22-2010, 08:51 AM | #3 | |
Rep 12,565
21207587369 Clutch - Clutch & flywheel - Pressure plate Pressure plate, z4, 3.0l, 3.0si 2006 - 2008 |
07-22-2010, 09:11 AM | #4 |
Bad Lieutenant
233
Rep 3,517
You sometimes grow into defects as a car ages, clutches and suspension are like this I notice. Someone else drives the car and says: "damn your shocks are blown". Agree this is probably the way it was supposed to be when new and it hasn't broken in yet.
07-22-2010, 09:38 AM | #5 |
Rep 12,565
good stuff, now i just gotta figure out if the modified cdv is still there. because the clutch is so much smoother than before, i can't tell if the cdv is there or not, lol
07-22-2010, 09:58 AM | #6 | |
Rep 102
EB |
07-22-2010, 10:23 AM | #7 |
Rep 12,565
correct, shifts are smoother but i miss the heavy feel of the original clutch. that heavy feeling made it easier to pinpoint the engagement point.
07-22-2010, 12:26 PM | #8 |
The Photographer
76
Rep 628
re-bleed the clutch...?
John Batte Photography / Flickr / Facebook 2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob |
