03-06-2016, 08:53 PM | #1 |
1621
Rep 4,294
KW Clubsports settings and setup.
Hi guys, installed my KW's yesterday, took it for a drive and then went to my alignment place and had the car setup to my likings.. (pretty much used the settings i had on my previous setup), but not sure that will work with this setup.
I set the car up with -3.0 degrees of camber up the front and 1.7 at the rear, with only a smidgen of +toe in at the front and +0.26 at the rear. car drives great, only issue is, its too dang low, after settling for a little bit, depending what corners its doing it rubs a lot.. so ill up the suspension by 4mm today, hopefully that will sort it out. question: if i increase the ride height, will i need to re- align, re csamber the car? or can i go up and down a bit without too much hassle? cheers Thinking about it now, i might be thinking that 3 degrees at the front is rather a bit too aggressive, and might change it to 2.3-2.5??
Powered by Last edited by Vanne; 03-06-2016 at 09:11 PM.. |
03-07-2016, 03:30 AM | #2 |
Rep 11,667
Ride height will definitely change the alignment.
03-07-2016, 09:01 AM | #3 |
1621
Rep 4,294
yup, thought so.. oh well, ill have to head back in then. changed the ride hight up about 4 mills at the back and about 10 mills at the front.. no rubbing now.. had a quick fang today and the ride is ... awesome.. love the feedback from the road, i have my damper set in the middle.. 8 at the back and 10 in the front.. thought id start somewhere neutral.
Powered by |
