      10-31-2010, 02:14 PM   #23
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Originally Posted by pal View Post
I went with the Turner Motorsport studs as they have a an allen key on a bullet'ish nose. Plus Turner is a respected company with a motorsports history so hopefully the quality is good.
+1 on these, they are what I have, just regular lug nuts as well.
They are awesome for getting the wheels on and off easily and then not having to worry about cross threading the lugs. I've found the short ones can work with a 15mm spacers too, but that is somewhat dependent on the wheel.
      12-24-2010, 02:42 PM   #24
wrose
Drives: 2007 Z4MC
2006 Z4M Roadster  [8.50]
2007 Z4MC  [0.00]
2005 X3  [0.00]
wheel stud conversion
What length of wheel stud should I use with OE wheels ?
Will most likely buy from TMS
Thanks
Wayne
      12-25-2010, 08:31 PM   #25
dekaliber
Thanks
Wayne
75mm is plenty for OE wheels. I just installed them on my car recently as well.
      12-27-2010, 09:02 AM   #26
2286
Thanks
Wayne
But if you know you're not going aftermarket, then you can go shorter which will be cheaper and wont require extended lugs (not that these are necessary but might look weird with studs sticking out so far)
      01-01-2011, 08:13 PM   #27
RBull
Drives: 2007 M Coupe
I have the 75mm also from TMS
      01-02-2011, 07:47 AM   #28
2286
and...?
      01-02-2011, 01:49 PM   #29
RBull
^they're fine. same as post #22
However I run a 12mm spacer up front. I was doing that in the rear too but the Yokohamas AD008 in stock size are too wide. The studs aren't as noticeable in the rear anyhow because of the wider wheel.
      05-07-2012, 10:25 AM   #30
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Anyone know where I can get a bronze colored 90mm stud kit? I'm assuming thats the size I need for my 20mm spacers
      05-07-2012, 11:33 AM   #31
2286
No such thing (or not that I know of). You'd probably be better off looking for extended lugs in bronze, since that's what you'll see anyway after everything is mounted.
      05-07-2012, 11:43 AM   #32
ZStig
279
I found these, but I'm doubting that they're good quality
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
      05-09-2012, 12:58 AM   #33
ZStig
279
anyone heard of this brand? http://www.jhpusa.com/store/pc/viewC...idCategory=680
      05-09-2012, 02:06 AM   #34
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Those should be strong enough for anything you throw at it. Go for it
      05-09-2012, 09:42 AM   #35
ZStig
279
75mm turner studs are long enough for 20mm spacers, right?
I ordered a set of those gold chromoly lugs. Should look good on the matte black TE37s on sepang
The 75mm studs are on a 1-2 week backorder right now
      05-21-2012, 04:48 PM   #36
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
I purchased a stud/lug set at Bimmerfest from Motorsport Hardware.
75 mm Bullet Nose Studs & Neochrome Lugs
http://www.motorsporthardware.com/cm/Products
http://www.facebook.com/MotorsportHardware
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      05-21-2012, 08:28 PM   #37
Drives: M2 Comp
IIRC, Max for 75mm stud is a 12mm spacer.
      05-21-2012, 09:00 PM   #38
mfanatic325
///M-fanatic
Taiwan
193
haha I like the neochrome look, but unfortunately they're crazy played out by the ricer community
Such a shame, cause they're pretty to look at, and the ricer representation doesn't do them justice at all
      05-21-2012, 11:15 PM   #39
ZStig
279
I ended up with the 90mm turner kit + their shorty zinc coated nuts.
      05-22-2012, 11:13 PM   #40
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
so much want. this kit is like $350
'07 MCoupe
lots of mods
      05-22-2012, 11:18 PM   #41
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
matching red caps really set it off
'07 MCoupe
lots of mods
