05-22-2013, 07:03 PM | #1 |
///M-fanatic
193
Rep 3,885
WTB: Z4M LSD/Differential
Looking to buy an LSD unit for my Z4M and/or a full differential housing with internal bits still in tact. Low-mileage preferred, and unit must be in great working condition. Please let me know if you have one available, thanks!
Looking to either pick up locally or have it shipped to Cupertino, CA zip code 95014. |
05-22-2013, 10:27 PM | #5 | |
///M-fanatic
193
Rep 3,885
edit: I just re-read your post. You were referring to perhaps purchasing a whole differential unit from those that upgraded to shorter final drive ratio? Well...I think most people rebuild their diffs (like I did originally). In which case, they won't have a diff sitting on the side available for sale edit2: Also, it looks like RealOEM doesn't provide an inside-look for the differential. They only allow you to buy a majority of an entire unit I suppose.. Last edited by mfanatic325; 05-22-2013 at 10:33 PM.. |
05-23-2013, 02:11 AM | #7 | |
///M-fanatic
193
Rep 3,885
I need to replace just the LSD unit, and so I'm looking for a "pumpkin" so to speak for its internal bits. |
05-23-2013, 09:29 AM | #9 |
Rep 503
Drives: Z4 M Coupe
Out of curiosity how did you diagnose the LSD issues?
05-23-2013, 11:22 AM | #10 | |
///M-fanatic
193
Rep 3,885
I went to an independent BMW race shop to have some rear ticking issues checked out, and that's when they found that my rear diff had excessive up/down play. They said something about spider gears. But ultimately recommended I get a new LSD unit. At first I thought a whole new diff was required but they said "no no, only the LSD unit inside". |
05-23-2013, 11:56 AM | #11 | |
Rep 2
Rich 713-828-2874 |
05-23-2013, 01:32 PM | #12 |
///M-fanatic
193
Rep 3,885
I don't believe our differentials are the same unfortunately (non-M Z4s don't have limited slip differential at all as far as I know). And used units typically go for $500....But thanks anyway!
