05-30-2013, 04:21 PM | #1 |
New Lifetime Replacement Policy
811
Rep 11,738
:: ECS Tuning :: Z4 BMW Performance Big Brake Kit|Back In Stock
Now that your pocket rocket will go from zip to 60 in a flash, have you considered how you're gonna stop it? Would a fresh stock of super stoppers interest you? Consider the ECS Big Brake Kit. Massive six-piston calipers with pads already loaded; semi-floating rotors; ECS caliper brackets; Exact Fit brake lines, Super Blue brake fluid, and all necessary hardware. Everything you need to install a high performance braking system, delivered in a single box. Fitment: BMW Z4 2.5i BMW Z4 3.0i BMW Z4 3.0Si Click HERE to order today!!! |
06-06-2013, 01:30 PM | #5 |
"The Midas Touch"
519
Rep 1,055
Drives: F87 LBB ///M2
Does this fit Z4M?
06-06-2013, 02:42 PM | #6 |
811
Rep 11,738
06-17-2013, 10:06 PM | #8 |
Rep 1,530
Will this fit the 3.0si with stock 108 rims?
06-18-2013, 09:08 AM | #9 |
811
Rep 11,738
We have a fitment template found HERE, which you can print to insure the kit will fit behind your wheels. That being said the 18 inch Style 108 will have enough barrel space to clear the kit, you may run into issues with the back of the faces making contact with the caliper. The contact with the caliper can typically be solved with a 5mm spacer, I would take this as an opportunity to measure your car for spacers and "flush" the wheels out closer to the fenders for a more aggressive look.
03-25-2015, 12:00 PM | #10 |
811
Rep 11,738
04-09-2015, 11:23 AM | #11 |
811
Rep 11,738
04-13-2015, 12:09 PM | #12 |
811
Rep 11,738
04-13-2015, 03:01 PM | #13 |
811
Rep 11,738
04-13-2015, 04:17 PM | #14 |
811
Rep 11,738
08-11-2015, 08:41 AM | #16 |
811
Rep 11,738
The calipers in this kit are BMW part numbers 34116786741 and 34116786742 they can be found HERE on the site.
-James |
