      02-25-2012, 05:49 PM   #1
bigbacon
Drives: 03 Z4
12,000 inspection on dash
i've had the car since Nov. and I am confused by the dash message when I turn on the car.
it says 12000 inspection and it says that all the time. I swore when I first got the car is had a mileage thing showing that changed.
So does it count upward and then tell you when to get service or what?
      02-25-2012, 06:05 PM   #2
mshanno1
Drives: 2007 M Coupe
It should count downward until your inspection is due
      02-25-2012, 06:08 PM   #3
bigbacon
Drives: 03 Z4
so what if it has stopped counting down? it has said 12000 for a few weeks now.
      02-25-2012, 06:53 PM   #4
tekmoe
tekmoe's Avatar
55
Drives: ///M
Try to reset it and see if it fixes it. Search for Z4M inspection reset on Google.
      02-25-2012, 06:55 PM   #5
bigbacon
Drives: 03 Z4
what if I dont have a M?
NM, found it.
wonder why it freeze like that.
      02-25-2012, 06:58 PM   #6
tekmoe
tekmoe's Avatar
55
Drives: ///M
It's the same procedure for non M's I believe.
      02-25-2012, 06:59 PM   #7
tekmoe
tekmoe's Avatar
55
Drives: ///M
DIY - RESET SERVICE INTERVAL (only for Z4 and E46)
1) With engine off and key not inserted keep pushing the left button on the instruments cluster ;
2) Insert key and turn to position 1 (do not leave the previous button) ;
3) Wait about 5 seconds (button alway pushed) until the service will show on the display ;
4) Leave the button for a moment and then push it again until the rESET on the display will start flashing ;
5) Now release the button and quickly push it again when rESET displays when flashing
http://www.zpost.com/forums/showthread.php?t=196206
