02-19-2012, 02:02 PM | #1 |
Rep 251
I know this is wrong place but I need your help
Hello everyone, My wife currently owns a 2008 Mazda3 2.3L.
Because I have bad experience with mechanics Mazda and BMW - I decided to change all my fluids myself from now on. Yesterday I went to change the oil in the mazda and I noticed a nasty black spot under the engine/transmission. Then I looked closer and it appears that something is broken or missing..... can you take a look at the pics below and let me know what this means.... The car only has 26k on it and so far the car runs fine.... but I'm sure that hole is not supposed to be there. Many thanks to all. |
02-19-2012, 02:38 PM | #2 |
Rep 409
don't know about a mazda...
but on many cars that hole is simply an inspection hole for mechanics to see what's going on in the flywheel / tq convertor / clutch area to check for leaks at the rear main seal. by my logic (take it or leave it), since there is clearly oil coming from the inspection hole... the rear main is leaking... or in the case of an automatic trans, the trans front pump is leaking... or both. this type of issue is quite common with mercedes-benz, so it's not too far of a leap to consider it happening to a mazda. others chime in if i'm way wrong.
02-19-2012, 10:03 PM | #4 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Looks like motor oil to me. Probably rear main. UGH
02-19-2012, 10:05 PM | #5 |
Dark Sider
129
Rep 1,779
Googled a bit cause I'm bored. Looks like there has been issues with leaks between motor and tranny ,caused by bad seal on the oil pan gasket. Could be a possibility.
02-19-2012, 10:37 PM | #6 | |
Rep 409
i was going to do the same thing until i saw this. now that you've done the work, i'll go back to being lazy.
02-20-2012, 08:18 AM | #7 |
Rep 99
Drives: 2007 z4 3.0si Coupe
As v3.0si said, that hole is quite likely just an inspection/access hole. It's too perfect a cut. As far as the fluid stain, could that not just be residual from a sloppy overfill/drain during a fluid change?
Rus |
02-20-2012, 11:55 AM | #8 | |
Rep 238
02-20-2012, 10:23 PM | #9 |
enthusiast
48
Rep 1,695
I am going to say its nothing. The oil surrounds the hole and is usually blown back. Need more pictures, but if the oil was coming or anything to do with the hole, it would not look like that.
02-21-2012, 12:06 AM | #11 |
Rep 251
Hello everyone and thanks for replying.
I ended up bring the car in today to have it checked. The tech brought me in while the car was up in the lift, he feels or tried to convince me that there was a leak from the engine filter area and some how the oil ended up where the spot is.... bunch of krap! if that was the case the entire bottom of the engine and trans.... would be oily and dirty. I'm going to check every weekend and make sure I don't see any more oil stains under the engine. So far - it looks like it's a normal Mazda thing to have that hole there, but I'm not 100% sold.... that oil mark did not get there from the filter shown on the last pic. Thanks everyone. |
