      02-20-2012, 08:36 PM   #1
ljkiter
Drives: z4 35i manual
Disa issue. Clicking sound
I checked the other threads about total failure but my vacuum
Seal seemed fine but has a small wiggle room in the open position. I tested the valve and it stays put when I put my finer on the hole. Is it dying and if so is there anything I can do to stop the wiggling? I'm guessing that's what is causing the noise.
      02-21-2012, 09:00 AM   #2
imz4n
imz4n's Avatar
Drives: 2006 3,0 si TITANIUM SIlVER
The top of the flapper has a metal pin that holds the flapper to the hoop/cage that works loose or out. Another source of ticking is the Vanos. If vanos is a issue, I would expect you to complain of lack of throttle responce. Check youtube for video's of both. On startup a source of ticking is the secondary air pump that only lasts for 20 seconds or so, this is normal.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
      02-21-2012, 10:07 AM   #3
ljkiter
When I unplug the Disa, the sound goes away. I was wondering if anyone here had the same wiggle room issue. It moves a cm in either direction if I hold it by the body and turn it back and forth. I figured someone might be able to help solve the wiggle issue maybe?
      02-21-2012, 10:20 AM   #4
ljkiter
Found this link.. Maybe I'll try it
/www.bimmerfest.com/forums/showthread.php?t=538855
      02-21-2012, 11:41 AM   #5
imz4n
imz4n's Avatar
I think the part bought new is only like $59. That is what I was charged from my repair guy anyway.
      02-21-2012, 11:45 AM   #6
Shipkiller
Shipkiller's Avatar
Drives: Me
As stated before, the metal pin is the most trouble. If it comes off, it will be sucked into the engine... That's BAD.
Since you pulled the connector and the noise stopped, then the DISA is the issue. If it were me, id replace the DISA. It only has two torx screws that hold it in place. 20 minute swap.
      02-21-2012, 11:54 AM   #7
Neegra
Drives: TiAg/Imola MC
Read a couple of the posts on the thread and came across what seems like the most useful post. Pasting it in case you didn't notice it:
http://www.bimmerfest.com/forums/sho...2&postcount=12
