04-08-2012, 05:12 PM | #23 | |
Rep 11,667
is it a simple reset? I understood there was a calibration procedure.
04-08-2012, 09:07 PM | #24 | |
704
As to how to actually code it, and the procedure, I really don't have a clue. I've been curious, but haven't wanted to try messing with it, since it seems like something that's easy to screw up. (I really need to buy that TIS disk so I can look these things up.) Next time I have the scanner hooked up (which requires a re-image of my laptop, or else I'd be out in the garage now) I'll look into it a bit more. |
04-09-2012, 05:14 AM | #25 |
Rep 2,138
Drives: Me
04-28-2012, 06:00 PM | #26 |
704
Yes! Finally. Running XP alongside my Linux install can be a pain at times (not Linux, XP).
In the LEW Module in the P.A. Soft Tool you can see the steering wheel angle itself and there's a LEW adaption button. The first image shows the readout from the sensor with the steering wheel centered and wheels straight ahead. The second image is the "clear adaption" option--this is what I remembered from looking at the tool's options before, and what I think will reset the SAS. (Now that I see it again, I have to admit I'm a bit less certain as I'm not 100% sure what would happen if I "push the button".) I'd assume you'd make sure the wheels are pointed straight ahead, steering wheel is centered, and you'd click it. But there's very little documentation available on just what it does. Maybe I'll be a guinea pig and follow what would seem to be the logical steps and press the button. If you hear a boom, that's my SAS or DSC going all wrong. If I mess it up, I'll get my try and get a good explanation on the whole SAS thing from my indie shop. |
04-28-2012, 06:07 PM | #27 |
Rep 11,667
Excellent!!!
04-28-2012, 08:00 PM | #28 | |
Car Geek
3626
Rep 3,594
Windows 7 also works well as a guest O/S on host Fedora 16 and Mac OSXs (based on info from people I know who are doing this). |
04-29-2012, 05:07 PM | #29 | ||
704
I'll scan it again in a few days (or next weekend) and see if there are any errors and whether driving turns up any issues. Quote:
04-29-2012, 09:48 PM | #30 |
Rep 11,667
Thanks for being the guinea pig on this.
The thing I find strange is that there isn't something more precise. This might be best done on an alignment rack.
04-29-2012, 10:08 PM | #31 |
704
Agreed about the alignment rack. After Googling a lot on Steering Angle and related terms I found very little out there aside from the "clean and re-solder" fix. The rest was speculation, or "you can't do it" "yes you can" back and forth. No definitive procedures, methods, or DIYs to be found (at least via my efforts). Wish there was more on this.
05-02-2012, 01:32 PM | #32 |
Rep 924
So how important is it to get the sensor reset after an alignment? Since it's news to most people, I'm guessing not very? Only if you're having major problems with DSC?
05-04-2012, 01:08 PM | #33 |
Rep 924
So I just contacted a very highly Yelp-reviewed alignment shop (recommended by Mfanatic) and asked about the SAS. He said he wouldn't be able to align my BMW because he can't reset the SAS. Is SAS really a big deal after every alignment? Can I get the alignment done and then go somewhere else to reset the SAS? Seems like most alignment shops can't deal with SAS, and the indie shops with the equipment don't do alignments
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts '09 X5 35d — Space Grey / Saddle Brown 20" Forgestar F14 / SCR Delete Last edited by RADRACR; 05-04-2012 at 01:13 PM.. |
05-04-2012, 03:43 PM | #34 |
704
Short answer, we don't know for sure. However, since SAS looking for the wheel to be centered, and the wheels straight ahead, if the alignment were changed significantly (which is what you want to do) I'd expect it would need to be reset.
So, you probably could have the alignment done and have someone else reset the SAS. But the cost of the reset s/b included in the alignment cost if you ask me. |
05-04-2012, 04:48 PM | #35 | |
Rep 924
I just contacted a BMW specialty indie shop and he said I could bring the car to them to reset it after my alignment no problem.
05-04-2012, 06:48 PM | #36 | |
Rep 11,667
The only way to be certain that you are straight is on a rack or with string lines.
05-04-2012, 09:40 PM | #37 |
Car Geek
3626
Rep 3,594
I've not had any problems with the SAS after doing aliignments by making sure that I determine the steering wheel horizontal position first by taping a spirit level to the steering wheel (making sure it is even relative to the spokes), then making sure that the front toe is always even left and right with the steering wheel level. Then I roll the car backwards and forwards a couple of times and re-check for symmetry.
08-28-2012, 01:44 PM | #38 | |
Rep 11,667
I have had 3-4 alignments done along with multiple suspension changes. I have some niggling handling related issues & am becoming more & more convinced that the SAS needs to be done on my car. I all is still good Ron I'm ordering the software package & doing this myself as well.
08-28-2012, 02:37 PM | #39 |
704
No changes to report, no issues with my reset procedure in driving or in subsequent scans.
I can't promise you that this will 100% resolve whatever issues you're having. That said, Aerobod's procedure makes sense, I'd follow that, set your alignment, and then clear the adaption. It might be even a better idea to also also use the scanner to see if the SAS agrees with the spirit level settings for level/zero on the steering wheel before buttoning things down during the alignment itself, and before clearing the adaption. Let us know how this pans out! |
08-28-2012, 03:35 PM | #40 |
Rep 11,667
That's what I had in mind.
When I set up my string lines I'll know where (current) zero is at the wheels irespective of the steering wheel itself. Checking with the software will tell me how far my SAS is out. ....then do an alignment & reset SAS.
08-30-2012, 12:21 PM | #41 |
Rep 180
I was denied an alignment from Sterling BMW in Newport Beach, CA!
Had my tie-rods repaced (siezed) and the Service Manager informed me that since my suspension was modified (H&R coilovers) the Tech was unable to get the car aligned to OEM Specs and therefore could not perform the alignment. I was able to haggle them down to $150 for the alignment, maybe they decided that it as not enough $$$ and decided to send me somewhere else? What is going on with this Dealership? |
08-30-2012, 12:38 PM | #42 | |
704
You'll need to get an indie shop to do it. Sorry, I know that's a pain when you're there anyway. |
08-30-2012, 04:16 PM | #43 |
Rep 98
Drives: '90 Porsche 941, Z4 Roadster
My Porsche can only be aligned at the dealer or Porsche specialty shop. It cost me $260. I don't know about the bmws, but to align the rear wheels on the Porsche requires about 2.5 hours and a special Porsche tool that's 3 pronged and fits in the area around the spring plate.
08-31-2012, 09:24 AM | #44 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
Not trying to hi-jack this thread, but my experience with BMW maintenance is that they are only allowed, by BMW, to do OEM-specified work. I found this out when I inquired about a future brake job (covered under my extended maintenance plan) using ceramic brake pads instead of OEM and they told me they could not install ceramic pads on my ///M because ceramics were not specified for that application. Talk about making a case for going to your local indie shop!
Oh, and our local independent (Race Shop & BMW/MB/Porche) charges $150 for their 4-wheel alignment.
2008 ///M Roadster
