      03-11-2014, 07:15 PM   #1
1SerieStud
1SerieStud's Avatar
183
Drives: '11 VO 1M (498 of 740)
Rubber/weather trim around windshield.
Folks,
One of the DIY's that I'd like to tackle one of these days is the replacement of the rubber trim around the windshield. The one on my car is not flat/flush against the roof or a-pillars (it's a little lifted), making me wonder if this is indeed the way it's supposed to sit, or if it should be nice and flush. The reason I have doubts is that it doesn't seem too worn out or hardened, like the cowl cover did before I replaced it.
Has anyone done the job and can this rubber trim be replaced with the windshield on the car? Or does it need removal?
Thanks!!
      03-11-2014, 07:41 PM   #2
the dink
Drives: 2005 Z4
First page in the DIY section has thread on this very thing.
      03-11-2014, 08:04 PM   #3
WAMz4
WAMz4's Avatar
Drives: 2006 Z4 3.0si Roady
And here is the best price I've found for it -http://www.rmeuropean.com/Part-Numbe..._E095124A.aspx
      03-11-2014, 10:49 PM   #4
1SerieStud
1SerieStud's Avatar
183
Thank you folks!
      03-12-2014, 07:33 PM   #5
papitosabe
Drives: '06 Z4 Coupe
getbmwparts has it for $28 IIRC
edit-- it is $28
      03-12-2014, 08:12 PM   #6
1SerieStud
1SerieStud's Avatar
183
edit-- it is $28
Nice…thanks!
The one on my car seems fairly new…I almost get the feeling that the prior owner replaced it but didn't install it properly. Any recommendations? Should I try to push it into the groove and see if it goes flush? I'm not sure if he used any silicone adhesive or not…not sure what to expect.
      03-12-2014, 08:56 PM   #7
msh441
msh441's Avatar
17
Drives: 2007 BMW Z4 M Coupe
Thanks! Mines in tact... But scored up/gouged on one side. I've thought about replacing, but assumed it would be too expensive.
      03-12-2014, 10:55 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
There's no adhesive required.
It really doesn't do anything but cover the edge of the windshield for looks.
If it's in good shape and doesn't seem like it's going to crack, I would suggest pulling it off and making sure there's nothing lodged under it.
Clean everything up nicely and put it back on.
It hooks around the edge of the windshield and then the outer edge just pops down into the slot.
      03-13-2014, 07:21 AM   #9
1SerieStud
1SerieStud's Avatar
183
Got it! Trying it this weekend! Thanks.
      03-13-2014, 07:41 PM   #10
1SerieStud
1SerieStud's Avatar
183
Could someone please snap a quick shot of the rubber trim specially on the of the glass that mates to the roofline? If possible, take a picture from the side or slightly angled from behind the trim (from the back of the car)…I'm interested to see how it's supposed to sit.
Thanks!
      03-14-2014, 12:52 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
      03-14-2014, 02:22 PM   #12
KLH
Drives: 2006 3.0si
I had mine replaced under warranty by my local dealer. It took them two full days to complete the repair and yes that's with the part already received! They still managed to scuff the passenger side leather door card....go figure. Of course I was told the damage was there when I brought my car in.....yeah, right. DIY is the only way to go....I wish I would've gone the route you're going.
      03-16-2014, 01:59 PM   #13
RecycledTeen
RecycledTeen's Avatar
Drives: Looking for E85
I noticed after having mine replaced (it was cracked and deteriorated in some spots) that wind noise was significantly reduced, perhaps due to the way the wind hit it. Dunno.
But also not an easy DIY - careful with that windshield!
      07-29-2014, 12:43 PM   #14
TCZ4
Drives: 2015 428i Convertible
I've noticed the center area right above the rearview mirror starting flapping and lifting with "spirited" driving." I think this was replaced 2 years ago prior to the car's purchase, but wondering if it was replaced incorrectly.
Given the cost I'm thinking about just replacing it, but if I push down hard and go along the entire roof, it seems to sit back down into the groove. But my area has been 100 degree plus, so maybe its becoming too pliable before I drive "spirited."
What makes this a hard DIY?
      07-29-2014, 02:42 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
I found that part to be easy. Getting the wiper arms off the replace the cowl was a bit of a faff.
If it's just flapping, but otherwise not falling apart, I would pull that section up and squirt some silicone caulk under it.
      07-29-2014, 02:46 PM   #16
TCZ4
Would that make it very difficult to remove if it needed to be replaced? What kind of caulk would you recommend? I don't want to have it too permanent and cause more damage long term.
      07-29-2014, 03:12 PM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
Just general purpose clear silicone.
The cheaper the brand, the easier it will be to clean up when you replace the part.
It won't really make it hard to get off. If it starts to decompose it'll come off in chunks anyways.
You'll just have to peel the caulk off with your fingernails.
Use it sparingly.
