      10-01-2007, 11:30 PM   #1
Waldorf
Black Opps field agent
Waldorf's Avatar
Drives: 135i M
Arrow Z4 M Definitive Wheel Spec Thread
DISCLAIMER : Don't tell I'm anal. I know I am
I don't have the answers YET but let's make this thread definitive and opinion-free. This thread is only for the Z4 M because the offsets are not the same (at least on the front).
Let's stick to verifiable facts about wheel dimensions and offsets. I did a bunch of research and even created a little wheel-and-offset calculator in Excel that you can download to contribute to this thread. In it, the variable numbers are in BLUE and the delta values are in RED. The EXT and INT columns are (in millimeters) the External and Internal distance between the wheel hub's face to the edge of the rim.
The reason why I'm doing this is because I want to get two sets of wheels, 19"ers staggered for summer and 18"ers identical for winter and keep the original wheels for the track.
I don't want to roll any part of my fenders, nor do I want any rubbing.
Original Z4 18" wheel sets don't seem to have the proper offset to fit correctly.
I would also prefer not to have to use any spacers, especially on the front, while keeping the track with the winter set even or marginally wider in the back.
our original wheels are the following size
F 18 x 8 ET42
R 18 x 9 ET30
The original E46 M3 CSL wheels fit really tight with the following specs:
F 19 x 8.5 ET44
R 19 x 9.5 ET27
I spoke with TC Kline about it and he reckons that the following specs will fit under the stock bodywork:
R 9 ET40, 35 and 28
R 9.5 ET25
Those of you who have aftermarket wheels, please post the specs that you have and comment on the fit. Let's make this thread a useful resource. As you add to it, I will maintain this first post so that the information is easily found.
Cheers,
Olivier
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
      10-02-2007, 06:50 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Currently running:
Fronts = 19x8.5 ET35 with 245/35 PS2
Rear = 19x9.5 ET22 with 275/30 PS2
Rubbing:
-lowered on H&R
- just a touch of rub on fronts... plastic liner right at the fender opening, front edge
- cured with a heat gun 60 seconds / side
- no problem at rear
*note tire selection (profile) will impact clearance issues.
Winter:
- running non staggered with 8.5" M6 reps
OEM wheels:
- +1 for track use
      10-30-2007, 11:51 AM   #3
kav
Drives: Z4M
Could you please explain how to use the calculator?
Neat Offset calculator:
http://www.1010tires.com/WheelOffsetCalculator.asp
Thanks.
      10-30-2007, 10:20 PM   #4
Waldorf
Waldorf's Avatar
Drives: 135i M
i simply made mine to calculate in millimeters for more accuracy and to get the delta changes for inner and outer clearance.
the only numbers that you need to play with are the ones in blue.
of course, you can make it for another car if you changed the stock width (in) and ET (mm).
for example, i bought some wheels for the winter that are all 8" wide but ET 40 for the front and 20 for the back. the chart showed me that I needed an 8mm spacer for the rear. that way my rear track was altogether 0.6mm wider.
the 1010tires calculator is fun and it's the one that i used before i got the idea for the excel calculator, now i can have a better immediate view of my whole setup.
      10-31-2007, 09:42 AM   #5
unionjack
Conceited Prick
unionjack's Avatar
14
Drives: Z4 M Coupe previously
2007 Z4 M Coupe  [0.00]
I'll be running the following when I order my new wheels.
19x8.5 et35 on 245/35
19x10 et25 on 275/30
previously
AW/IR | Premium Package | Heated Seats | Navigation | Valentine One | Shorty Antenna | Black Kidney Surrounds
      12-06-2007, 01:00 AM   #6
M-Zed-4
M-Zed-4's Avatar
Drives: Titanium Silver Z4 M Coupe
Hello, I am very new to this forum, but I just purchased a 2007 z4 m coupe. I wanted to have two sets of wheels and tires for my car (one for the track and the other for the road). I previously owned a Mercedes C32 and I purchased a set of BRABUS Monoblock IV, five-hole design, 8,5Jx18, modular, tires 225/40 ZR 18, optionally 9,5Jx18 modular rear with 255/35 ZR 18. I wanted to know if there is any way at all if these might work with my current vehicle. Any advice would be greatly appreciated. Thanks
      07-23-2008, 12:57 PM   #7
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
would 8x17 ET35 E90 wheel fit the roadster without rubbing? I think it will stick out a bit, but enough to be ok for front and back or...? Or will be issues on the back as it will stick out almost 2cm..
in europe the Z comes with 16 and 17in wheels, hence the question. Does the Z need basically the usual E46 wheel offsets?
F30.F11.E86.E90.E90.E36
      08-13-2008, 10:54 PM   #8
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
Not sure what the offsets are for the E46 but I was offered a set of E46 M3 wheels today, price hasn't been negotiated yet, but was wondering if M3 wheels would fit on a 03 2.5i roadster? Would I need spacers in the rear cause the guy told me that the wheels are 9 inches wide and with tires they are almost 10-11 inches wide, he referenced the with of the rear tires to 12 inches.
Has anyone tried this style of wheel on a Z?
I wanted to ask and see if there would be any problems before I worked out a price with him.
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
      08-13-2008, 11:39 PM   #9
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Won't fit your car. Rear offsets are too aggressive. Putting spacers only makes it worse. You can put 4 OEM front E46 M3 wheels on your Z4 if you'd like though.
And he's running 305 rear tires on his E46 M3? Ummmmm.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      09-03-2008, 02:21 PM   #10
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
I'm likely going to run an SSR CompH in 19x8.5" sizing up front. It has an offset of +43 so I may use a 5mm spacer to bring it to 38 which, from what research I've done, seems to be pretty close to perfect. I've seen people saying 35 rubs when lowered so I want to avoid that since I'll likely be lowered. But the spacer gives me the ability to go back to +43 if necessary. In the rear, I'll likely run 19x9.5" sizings with an offset of 35. Again, I could use a spacer either in 10mm or 5mm to get the fitment right.
A lot of people shy away from spacers but if you get good ones and install them right, they're fine. I use studs/nuts so its even easier to remove and swap different plates on or off!
      09-09-2008, 03:38 PM   #11
Z4Kevo
Z4Kevo's Avatar
85
Drives: 2007 M Coupe
I am running the 19" M3 Competition wheels.
F 19 x 8.0 ET47 - 245/35R19
R 19 x 9.5 ET27 - 285/30R19
No Rubbing at all and it looks great.
      10-08-2008, 01:09 AM   #12
Alpine M
Drives: Silver/Red Z4MC
19 x 8.5 + 38 245/35/19
19 x 10.0 + 34 285/30/19
1.5" F 1.6"R drop. Mild rub in front inner fender liner. Rear is a clean fit.
      11-02-2008, 03:07 PM   #13
kalsonc
Drives: '09 E90 M3
would stock e90/92 18'' M3 rims fit on my 05 z4 3.0L w/o rubbing?
front 245/45/18 i think? and rear is 265/40/18
ET is either 40 or 35 in the rears
      11-08-2008, 05:50 PM   #14
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
A very good winter tyre fitment:
O.Z. Racing Ultraleggera 18x8 ET40 front and rear with 20mm spacers for the rear.
225/45-18 tyres all around, can be rotated if desired.
      03-04-2009, 07:36 PM   #15
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Is there any difference in the available clearances from one model to the next ???
As in Roadster=
Si=
M=
      05-12-2009, 12:17 PM   #16
TelfordZ4M
Drives: 07 M Coupe
fit?
Is this a good fit on a 07 M Coupe? 19X10et25 and 19X8.5et35
      12-08-2009, 05:46 AM   #17
xjeeper
Drives: M3
That'll work.
Interlagos Blue over black extended leather E86 M coupe.
0-60 in 4.21 (calculated from E.T.) 1/4 mile in 13.1 @ 106. Bone stock.
      12-20-2009, 07:29 PM   #18
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
oz ultraleggeras....z4m roadster fitment
i luv oz's...had an 18 in set on m s2000.
looking to purchase these (below) for the 07 z4m roadster....will these fit?
oem 18's:
front: et 42
rear: et 30
oz 18's:
front: et 40
rea: et 40
O.Z. Ultraleggera
Finish: Black Painted
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Rec. Tire Size:225/45-18
Weight: 18.6lbs.
Rear Fitment
18x9
Offset: 40mm
Backspacing: 6.57"
Bolt Pattern: 5-120
Rec. Tire Size:255/40-18
Weight: 20.8lbs.
      12-25-2009, 01:41 AM   #19
aerobod
Car Geek
aerobod's Avatar
3626
oem 18's:
front: et 42
rear: et 30
oz 18's:
front: et 40
rea: et 40
O.Z. Ultraleggera
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Weight: 18.6lbs.
Rear Fitment
18x9
Offset: 40mm
Backspacing: 6.57"
Bolt Pattern: 5-120
Weight: 20.8lbs.
They will fit no problem (I have the front fitment all round on my car, for my winter tyres with a 20mm spacer on the back). You may want to use a 10mm spacer on the back with 35mm long lug-bolts, although the wheel will just look a bit inset if you don't, but shouldn't rub.
      12-25-2009, 06:41 PM   #20
racerbruce
racerbruce's Avatar
3854
F 18 x 8 ET42
R 18 x 9 ET30
F 19 x 8.5 ET44
R 19 x 9.5 ET27
R 9 ET40, 35 and 28
R 9.5 ET25
Cheers,
Olivier
06-07 mz4 oem wheel weight....
what is the exact weight for front and rear oem wheels??
thanks
racerbruce
      12-25-2009, 06:47 PM   #21
racerbruce
racerbruce's Avatar
3854
06-07 mz4 oem wheel weight??
thanks
racerbruce
      12-26-2009, 08:55 AM   #22
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
oem 18's:
front: et 42
rear: et 30
oz 18's:
front: et 40
rea: et 40
O.Z. Ultraleggera
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Weight: 18.6lbs.
Rear Fitment
18x9
Offset: 40mm
Backspacing: 6.57"
Bolt Pattern: 5-120
Weight: 20.8lbs.
You need to use a 15 mm spacer on the back with those wheels with either wheel studs or correspondingly longer wheel bolts. Readily available from several reputable vendors.
