07-04-2022, 08:25 PM | #1 |
Rep 12,567
Front Fitment 9.5 et23 - How Much Camber
Assuming I want to run 255 up front, what’s the min camber? Anyone with actual experience?
07-05-2022, 07:40 AM | #2 |
Rep 1,373
I think the offset on the wheel might be too much... I run a 265 front with a 9.5" et30 front wheel and it has a lot of poke.
255 fits really nice with -2.6ish camber. 265 requires a min of -3
07 Z4 M Coupe AW/IR |
3002 tii2293.00 |
07-05-2022, 07:59 AM | #3 |
Rep 12,567
Thanks, that’s what I thought but having someone else validate is helpful.
07-05-2022, 12:31 PM | #4 |
Rep 687
Drives: 06 Black Sapphire Z4MR
The poke should be fine when static or just driving around, I am running 9.5 front, et28 with a 3mm spacer, I had used a 5mm before (effectively making et23) with -2.5 on 245/40 RS4 to clear my KW CS. You will find out just how little room there is though once you start hitting the track. I was rubbing on metal with the 5mm spacer with a fairly significant roll.
I have removed my helpers now which really helps so i moved back to 3mm and make clearance better. Next time round I am thinking of going 255/35, wider but smaller diameter may change the dynamics
Revolution of our Times
I will return to the track, one day. |
3002 tii2293.00 |
07-05-2022, 04:11 PM | #5 | |
Rep 5,329
would love to see some pics if possible
07-13-2022, 08:25 PM | #6 |
Rep 258
Apex has an amazing resource for thishttps://support.apexraceparts.com/hc...-Fitment-Guide:
2003 Z4 2.5i Roadster (SOLD)
2006 Z4M Coupe 2017 Porsche 911 C2S Cabriolet |
