      11-20-2020, 10:06 AM   #1
Emmrbee
Retired
Emmrbee's Avatar
Drives: 2006 Z4M Roadster
I found out during my winter storage oil service that I had stripped my oil pan threads when I performed my last oil service. Seems to be a common problem with soft aluminum oil pans.
Took me about a hour to repair with a steel insert with this kit. Worked like a charm!
Available from Amazon
      11-20-2020, 10:28 AM   #2
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Well done.
Was the cause related to cross-threading the plug when threading it in or perhaps over-tightening?
Racerbruce
      11-20-2020, 10:35 AM   #3
Emmrbee
Retired
Emmrbee's Avatar
Originally Posted by racerbruce View Post
Well done.
I suspect I applied to much torque on an already weakened set of threads. I used a torque wrench to install the plug last time with the correct torque value but it was not the best quality torque wrench.
      11-20-2020, 11:10 AM   #4
racerbruce
racerbruce's Avatar
3854
Got it - thank you for the clarity.
Racerbruce
      11-22-2020, 03:53 PM   #5
pungo
pungo's Avatar
I've never used a torque wrench on the drain plug, I just snug it up with a 3/8" ratchet. Those threads are pretty robust with plenty of them. Do you have an aftermarket drain plug by chance? Good you where able to fix it with a steel insert.
      11-22-2020, 05:07 PM   #6
Emmrbee
Retired
Emmrbee's Avatar
OEM drain plug but I'm not the first owner. Who knows how much that plug was torqued before I started doing the oil services.
      11-22-2020, 06:10 PM   #7
racerbruce
racerbruce's Avatar
3854
Well said -
Well said -
I used to take the beloved Red Roadster to a BMW stealership for service and repair.
I began going to a uber-great indi shop and the first time they changed the oil they reported the oil drain plug was SEVERELY over-tightened....
Ain't no cure for dumb.
Racerbruce
