11-11-2012, 01:15 PM | #1 |
Rep 516
Windshield Washers Problem
Hey guys, just noticed that my nozzles on the hood stopped working. Headlight cleaning ones still spray its just the ones on the hood that aren't operating. Anybody have any experience with this?
11-11-2012, 02:41 PM | #2 |
707
Rep 7,850
Have you traced the lines back to the washer pump? All of them are attached to the same pump, so sounds like a kink or obstruction in the line to me.
11-11-2012, 02:43 PM | #3 |
Rep 11,667
^whs
.....or plugged nozzles.
11-11-2012, 11:30 PM | #5 |
Rep 516
so today i took checked the nozzles and lines everything look clogg free and clear, i then decided to check the pumps. it looks like windshield nozzle pump went out, it showed rust on the outside of the unit. Since i had the tank out, i went ahead and checked to see if the grommets were clogged on both pumps, NOPE. Well now I happened to make the headlight washer not work as well -_-*. The pump is fine, i still hear it buzz, but no fluid is being channeled to them, i may have missed something. Got too cold and dark so i will attempt to fix this another day. Any ideas where I can get another pump cheap?
11-16-2012, 10:54 AM | #7 |
Rep 296
The headlight washers and winshield washers are two sperate pumps and line systems. My windshield washer pump (closest to firewall) recently went out as well, while it was at the body shop. I got a replament from a local auto parts shop that was cheap and I am running that!
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
06-22-2013, 01:30 AM | #10 |
636
Rep 3,124
First thing that went out on my car after I bought it used.
I saw the puddle on the driveway and thought "What's that? Oil? Coolant? Wait, this is washer fluid!" $26. |
06-22-2013, 03:22 AM | #11 |
Down Under!!
1621
Rep 4,294
yep, both Bimmers i bought used here had this.. loved the fact its bloody cheap to diy.
Powered by |
10-07-2013, 07:54 PM | #13 |
Rep 516
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
10-18-2013, 12:11 PM | #15 |
636
Rep 3,124
Either #4 or #6 here, depending on which one's leaking.
10-18-2013, 07:51 PM | #16 |
Rep 516
10-21-2013, 06:16 PM | #18 |
Rep 1,991
Mine started leaking a day or so ago. Ordered the new pump but can't find a DIY anywhere. I assume you have to empty the reservoir first? The one leaking for me is the windshield washer pump. Do you just unclip the electrics and pull it out or does the entire reservoir need to come out to do it?
10-21-2013, 07:56 PM | #19 |
636
Rep 3,124
I seem to remember I took the whole thing out so I could dump the juice into a bucket and save it.
Pretty sure there was only 1 bolt holding it on. If it's already empty, or nearly so, you can skip that step. The pump just pokes into the grommet/filter.
10-21-2013, 10:24 PM | #20 |
your average JAMF
3101
Rep 4,094
Mine just crapped out, then I stumble into this thread.. amazing. How simple is this thing to swap out? I figure I'll score one of those 3rd world jobs @ $6.88 from Ebay - how wrong can you go at THAT price??
'21 M2 Comp
'19 Golf R |
10-22-2013, 01:09 AM | #22 |
Down Under!!
1621
Rep 4,294
Really? Save the washer water that's in there? Come on, some water and a spot of windex and your done.
Powered by |
