07-26-2015, 11:00 PM | #1 |
Rep 29
ABS/DSC Hydraulic unit BMW Z4 34-52-6-769-164-02?
Any idea were i can get used ABS/DSC Hydraulic unit BMW Z4 34-52-6-769-164-02 for 2007 Z4 M coupe USED?
Thank you |
08-26-2015, 06:48 PM | #3 |
10634
Rep 4,852
There are specialized companies that can repair abs units. It's mostly the soldering on the pcb (which often is a very special ceramic pcb).
Are you sure the abs unit is at fault? (not one of the brake pressure sensors on the master cylinder or something like that)
