      04-30-2008, 05:30 PM   #1
pmhcold
Drives: 2007 Black Saphire Coupe
2007 Z4 3.0si sport suspension
Can anyone tell me the difference, if any, between the z4 coupe sport suspension and the z4 m suspension?
      04-30-2008, 05:48 PM   #2
Z4HN
Drives: '05 Z4 3.0i, '08 M3
The Z4M's rear axle is the same as the E46 M3. The front struts are essentially modifed struts based on the E36 M3's design.
Simply put, you can't put Z4M's suspensions on a regular Z4.
      04-30-2008, 06:05 PM   #3
vachss
Drives: Z4 Coupe
Z4M swaybars are 27mm/22mm Front/Rear where the 3.0si sport bars are 25/19mm. The rear bars do not interchange between M and non-M but the fronts might (I've heard that minor modification is required).
