06-09-2015, 01:24 PM | #1 |
Rep 170
Steering Colum
I have a 2003 3.0i Z4. I need to get a new Steering Colum. I have been looking at prices, and they seem to jump around a lot> Could someone Please help me out with this issue and hopefully suggest a good place to buy one, and what the price would be...
Thank You. |
06-09-2015, 04:20 PM | #2 |
Rep 2,704
Why do you need a new steering column?
06-09-2015, 06:25 PM | #4 |
Rep 2,704
Does it do it all the time or just intermittently? Mostly when the weather is hot...........
Are you aware of the sticky steering syndrome our cars suffer from?
06-09-2015, 06:33 PM | #5 | |
6 of Diamonds (ret)
82
Rep 566
Is the noise from within the cabin or under the hood? Does the steering seem sticky? You might get lucky and it be the rack or some other underhood steering component. Columns are not cheap on parts or labor. Good luck Bruce
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
06-09-2015, 06:36 PM | #6 |
Rep 170
It started little by little last month. I took it in to my mechanic thinking that the fluid might be low. But he told me that it's the Steering Rack. Because now, no matter what type of weather, every time I turn I get that grounding sound........So tell me What is the going price for a Steering rack (Steering Colum) Just the part.
Thank You. |
06-09-2015, 08:10 PM | #8 |
Rep 273
If you have an issue with the steering rack, address that first and assess the results before even thinking about any possible steering column problems. I haven't heard of the steering rack causing much trouble, but it's a relatively inexpensive part - Rock Auto shows a complete remanufactured EPS rack unit for 130.00 (+core), including inner tie rods. I would imagine other suppliers are similar.
06-10-2015, 04:30 PM | #9 |
Rep 170
It's the steering rack that needs to be replaced, not the colum. So I suppose that saves me a ton of money. Strange though. Even though it's an '03, it has less then 70k on the car. I wouldn't expect the issue that I'm having now until it was up around 130k.
06-10-2015, 09:03 PM | #10 | |
6 of Diamonds (ret)
82
Rep 566
1. Leave the car out in the summer sun all day with windows up. 2. Go drive it w/o turning on the AC. Do you have sticky/notchy steering? 3. If yes, turn on the AC and cool down the interior for a good 30-45 min. You may need to cool it down for several hours, ie put it in the garage, you are trying to get cabin temp down and ultimately cool down the steering column that's in the cabin 4. Does it go away or seem to lessen? Or you can do the above vice versa, I.e. drive it morning after car has been in a cool garage all night, then leave it out all day and drive it, etc.... Good luck Bruce
2007 Z4Si(gone)
06-10-2015, 09:41 PM | #11 |
Rep 170
Well this what happens in the morning. All is good, no sound. Drive it to a couple of meetings, then head back home. By the time I get back home I begin to hear it again. But like the other day when I was out and it was hot, I had the AC running and that seemed to make it worse and start to get sticky. Oh and without the AC I get the same noise and sticky steering. But I was told again that it was not the column but the Steering Rack.
06-11-2015, 12:51 PM | #12 | |
6 of Diamonds (ret)
82
Rep 566
https://www.bmwcca.org/forum/index.p...-mystery.5921/ http://www.bimmerforums.com/forum/sh...y-Steering-Fix That being said with this kind of mileage your mechanic could be dead on. If it bothers you then you need to try something. Easiest, cheapest first. That's probably the steering rack. If you are mech inclined its just parts and sweat. Probably don't need to tell you this will require an alignment when through. Good Luck Bruce
2007 Z4Si(gone)
