06-21-2017, 04:24 PM | #1 |
Rep 911
Z4 Coupe high speed stability?
How are you guys with high speed stability on these coupes? I'm talking 140mph+ on power (not cruising)? Any comments on alignment setup , wings (that actually prove to work, not just cosmetic)?
I'm less concerned about steering feel and more about the rear end staying firm planted and straight. I noticed my coupe likes to "hunt" a bit in the rear at 140mph+, making me rather nervous. Could this just be a design flaw: short wheel base, no rear aero, lightweight, no LSD, not geared for anything more than 170 (if wind isn't a factor) ?
Andre - 2J into a Z4 Coupe!
06-21-2017, 09:10 PM | #2 |
Rep 758
I can't speak for the coupe but my roadster has been pretty solid at those speeds on the track at Daytona. Even with gusty winds it hasn't felt unstable. Make certain the headlight switch isn't in the auto position and that the windshield wiper switch is in the fully off position. If they're not off, the brake pad wipe function is enabled which makes the pads just touch the rotors occasionally to keep them dry in the rain. They still do this even if it's not raining and all 4 corners don't necessarily make contact simultaneously. At normal highway speed you'd not notice it. At 140 you'd definitely feel it.
It could also be DSC/DTC thinking it needs to do something at those speeds and just touching the rear brakes alternately. I've experienced this at Daytona, but the banking also contributes to confusing DSC/DTC. I turn it off at that track as does everyone else I know that runs an E46 as they exhibit the same behavior.
Top Down 365
06-22-2017, 12:05 AM | #3 |
Rep 754
I take my Z4m over 140+ on my daily commute and it's stable on the SoCal freeways, all with traction off and sport mode on. I'm on 19 inch wheels if that makes a difference but the car feels like she's squatting down.
06-22-2017, 12:16 AM | #4 |
Rep 911
Maybe it's just me... I thought these cars were very unstable past 140.
My alignment specs are -2 camber rear, 0 total toe rear (can't go any more negative), 0 toe front, -1.6 camber front. Have my BC coilovers on middle setting all four, and 32psi all four tires. All undertrays in place. All new suspension bushings (upgraded front and all rears), all new wheel bearings. Car feels solid on the road in any other condition. Do you guys feel a wing is necessary? Keep in mind, I'm probably pushing 500whp right now, which may be some part of the issue She's solid if I'm feathering at 140, but soon as I step on it, it begins... On a side note - I find it funny I'm about 30mph shy of running out of gear She can definitely reach it in 6th that's for sure!
06-22-2017, 08:59 AM | #5 | |
1821
Rep 5,337
Don't know how you would expect any different when there's zero toe all around.
kaybat125.50 filtercoffee106.00 |
06-22-2017, 01:48 PM | #6 | |
Rep 758
Zero toe in the rear certainly isn't helping your cause. Rear toe in increases stability, toe out decreases it. On my 3.0si to get past 140 in the space available on the track it's floored the whole time right up to the braking point to turn into the infield at Daytona. It's very stable under those conditions, but I'd guess on a public highway with a crowned road and other pavement variations you're getting a lot more movement inputs to the suspension than I've seen. Plus I certainly don't have 500 rwhp as a variable.
Top Down 365
06-22-2017, 03:44 PM | #7 |
1821
Rep 5,337
Especially for a "high powered" car. As you tip in throttle, and weight shifts to the rear, rear camber increases. A charming side-effect is the toe INCREASES (toes out). If your goal is any sort of high speed stability for a high horsepower car, i certainly wouldn't align it with zero toe (since at speed, it will toe OUT as you tip in throttle).
06-22-2017, 04:06 PM | #8 |
Rep 911
Good points. Interestingly, I can't apply any more toe in. I tried to go -1/16 each side, but it is maxed at 0. Car actually had +1/8" toe OUT on each side when I had gotten it a while ago.
06-22-2017, 04:41 PM | #9 | ||
1821
Rep 5,337
http://www.pelicanparts.com/BMW/tech...rm_Bushing.htm Quote:
Actually, while you're in there, probably better just to replace the rear toe bushings with urethan or spherical bushings, especially for high powered cars.
06-22-2017, 05:51 PM | #10 |
Rep 911
I upgraded the rear bushings to rogue engineering RTABs, installed it myself. They were universal (could be installed in either direction). The rear upper bushings were replace with new OEM units. Lowers were untouched (they looked Ok).
06-23-2017, 04:45 PM | #11 |
1821
Rep 5,337
I think sometimes aftermarket companies assume that the toe bushings are installed CENTERED on the trailing arm. It is entirely possible that the factory position is not 100% centered leading to the aftermarket toe bushings to be just out of the adjustment range. If that is not the case, I would check alignment with another shop and see if they can add some toe-in for rear stability.
Another thing you can try to physically change the geometry in the rear, and if you haven't done so, is to use adjustable camber arms to push the bottom of the king-pin out. Go up to -2.5º of camber in the rear may add enough toe-in.
06-24-2017, 11:38 AM | #12 |
Rep 12,565
Tires would be another factor... what kind are you running?
06-24-2017, 08:34 PM | #14 |
Rep 758
Not me! Only on the track for me, no way I'd do that on the road.....It's risky enough in a controlled environment.
Top Down 365
06-25-2017, 09:35 PM | #15 |
Rep 911
Nitto NT555 G2. Got up to almost 160 at Pocono this weekend, squirmi-ness seemed to have not been to big of an issue. I did stiffen up the rear and front suspension, but it seems the +1/8" toe each side was definitely making it worse. Going to 0 was an improvement. I may raise the rear a tad which should then give me just the right toe in needed.
07-05-2017, 03:54 PM | #17 | |
Rep 23
- toe is toe out + toe is toe in If you had +1/8" toe, you had toe in. Maybe have the shop check again, you should have plenty of adjustment range in toe. You should target 1/8" total toe in for the rear. |
07-05-2017, 04:18 PM | #18 |
Rep 911
Actually, I do my own alignment, and I had toe out. Since negative camber points in at the top, I've always used negative toe as "pointing in at the front", although nomenclature is +toe = point outward (yes, a bad habit!)
As stated, I can't go with any toe-in in the rear as I'm maxed at my adjustments, thus 0 toe is all she can do for now. I bet the RCAB upgrade is what affected my limited adjustment unfortunately.
07-05-2017, 08:46 PM | #19 | |
Rep 12,565
07-05-2017, 09:00 PM | #20 |
Rep 911
Would love to go, just realized NASA holds local events...
I've only been on Motorsportsreg and will be at Pocono next weekend. Looks like HPDE1 is full for this weekend (I've been written off to Solo at a PCA event, but don't think NASA would start me at HPDE2) Would like to meet you as well! I'll see if NASA has some additional events between now and October!
07-05-2017, 09:33 PM | #21 | |
Rep 758
Top Down 365
07-05-2017, 09:49 PM | #22 | |
Rep 12,565
