02-24-2020, 11:34 AM | #89 |
Rep 335
I'm looking to put some Apec Arc8s on my Alpine White MC. Going to go with the 18x9/18x10 staggered set up and the eibach .08 springs with PSS tires.
Only question is matte bronze or antracite. Anybody have AW with either of these colors in wheel they could share? |
02-27-2020, 02:15 PM | #90 | |
Rep 6,804
We do have a few pictures with those finishes: Heres Anthracite: I don't have any shots of Matte Bronze on Z4s, but I do have some on an E46 M3: Let me know if you have any questions! -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
02-27-2020, 02:18 PM | #91 |
Rep 335
02-27-2020, 03:27 PM | #92 | |
Get off my lawn
938
Rep 1,162
I run APEX 18x9 et30 front, 18x10 et25 rear (lowered on KW coilovers) - common setup you should not have any issues |
02-27-2020, 04:18 PM | #93 | |
Rep 6,804
The 18x9 ET30 is a great front fitment for your car and will be a bit easier to fit than the 18x9.5. Depending on the tire size you run in the front, you may need a bit of additional negative camber with the 18x9 ET30 fitment. thanks! -Tom
02-27-2020, 04:22 PM | #94 | ||
Rep 335
I was planning to go 18x9 up front with a 255/35/18 PSS and 18x10 in rear with a 275/35/18. I have eibach springs let the 0.8" drop |
03-06-2020, 05:16 PM | #95 | |
Rep 6,804
In the rear, the 275/35-18 tires should be a great fit. Let me know if you have any additional questions! Thanks -Tom
03-07-2020, 06:52 PM | #96 |
Rep 155
Drives: M4; X4 M40i
03-19-2020, 11:22 AM | #97 |
Rep 131
OK stupid question time. 2003 Z4 completely stock.
Looking at a square set-up as I drive mine a lot and would like the option of rotating the tires to get a bit more life out of them. What size wheel & tire combo will fit all 4 corners without crazy camber adjustments. |
03-19-2020, 05:55 PM | #98 | |
Rep 2,706
I don’t have the answer but this thread has lotsa info. https://www.zpost.com/forums/showthread.php?t=398990
03-21-2020, 11:19 AM | #99 | ||
Rep 131
04-07-2020, 06:44 PM | #100 | |
Rep 6,804
-Tom
04-08-2020, 08:36 AM | #101 |
Rep 1,373
Thats my car. It is on Ground Coilovers running basically as low as they can go with a 275/35/18 square set up.
07 Z4 M Coupe AW/IR |
04-08-2020, 09:51 AM | #102 | |
Rep 131
04-15-2020, 05:53 PM | #103 | |
Rep 6,804
-Tom
04-15-2020, 07:56 PM | #104 |
Rep 131
Drives: 07 Z4 M Coupe
Here is mine and I love this setup! I run same wheels/tires on my E46 M3.
Apex ARC-8 18x9.5 et35 Square Michelin Pilot Sport Cup 2 265/35/18 Square Apex Spacers Front 5mm, Rear 12mm (I know you can't tell from this angle, but included for fitment) Lowered on JRZ RS Ones and other fun bits. |
04-16-2020, 11:47 AM | #105 | |
Rep 6,804
-Tom
Tags |
apex arc-8, track wheels, z4 m |
