      05-20-2015, 09:52 AM   #1
rmousir
Drives: 2006 Z4 3.0si
Ramps, Jacks, Lift
Hi Guys,
New owner here. I wanted to ask how you all get your z up in the air.
i have some nice ramps that I normally use with my other cars. Then when the front is up, I use the jack and lift the back end up and I put the rear wheels on rear while lift blocks. Since I've only had my Z for a couple weeks now, I have yet to put my car up on the ramps.
So my questions are:
1 - Where are the jack points?
2 - What do you use to get your car up so you can access the underside for oil changes and what not.
Thanks
Richard.
Ohio
2006 Z4 3.0si
      05-20-2015, 10:03 AM   #2
JCF
Drives: 07 Z4 M Coupe
This question has answers EVERYWHERE and I think it's even in the manual (shocking....)
Try harder next time.
Look underneath your car along the edges and you'll see 4 rectangular blocks, those are the jack points. There are also 2 center jack points (front and rear)
I'm confused though... If you have ramps why would you jack up the back as well to change the oil?
As for oil changes it would be faster to get a vacuum, that way you don't need to bother with raising it at all!
Originally Posted by rmousir View Post
Hi Guys,
Thanks
Richard.
Ohio
2006 Z4 3.0si
      05-20-2015, 10:04 AM   #3
schobyb
schobyb's Avatar
15
Drives: 06 Z4M Roadster; 2012 Cayenne
2006 BMW Z4MR  [0.00]
This one is a pretty good reference.
http://www.zpost.com/forums/showthread.php?t=484468
Where in OH are you? I'm just outside Columbus.
      05-20-2015, 10:14 AM   #4
rmousir
Thanks for the quick response.
1. I use ramps for the front and then jack up the rear and slide my rear tire blocks. This sets the car level at about 1' off the ground and this is with out jack stands and is safe and sturdy. I've been using this method for years.
http://budgetrestomod.weebly.com/wheel-blocks.html
http://budgetrestomod.weebly.com/ramps.html
I've read some articles on here about the vacuum, however it doesn't appear that my Z has a oil dipstick. Not sure the vacuum would work.
I'm on the east side of Cincinnati.
      05-20-2015, 10:33 AM   #5
itdnwiwbp
Drives: 330iZHP
Lift Stands. They're expensive and hard to get but worth every dime and the wait.
myliftstand.com/
      05-20-2015, 10:36 AM   #6
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
Yes, the Si does not have a dip stick, you have to do it the old fashion way. I used my Rhino ramps until I lowered the car, now I use Raceramps to change the oil. I also have a set Esco jack stands if I need to lift both ends up.
Remus, ZHP, Stubby, H&R Coilovers
      05-20-2015, 11:06 AM   #7
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
I would recommend these
http://www.amazon.com/BMW-128i-E46-3...ck+pad+adapter
I have a set, and they're very nice if you're using a floor jack with the standard round pad. It lifts the contact point up out of the floor jack "dish", so they're less chance of the dish contacting the car and damaging something.
They also work great with ESCO jack stands (best jack stands you can buy)
http://www.tooltopia.com/esco-10498....d-AaAqr28P8HAQ
      05-20-2015, 11:27 AM   #8
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Reverselogic also offers ESCO jack stands with custom built-in blocks for BMW jack points. A bit overkill but very cool.
http://www.reverselogic.us/jack-stands.html
      05-20-2015, 01:02 PM   #9
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
I have the ESCO stands and those things are obscenely nice. They are very tall though so even at their lowest setting, you will have to jack the car pretty high up.
I start off when lifting the front, by jacking up one of the front sides, using the jack pad behind the front wheel and my smaller secondary jack. This allows me to see the central front lift point and also allows my primary jack (long and low profile) to fit underneath the front bumper and reach the central point. Then I lift it using the central point, and put jack stands on the side points. For the rear, I stick a block of wood over my jack and lift from the area behind the diff, in front of where the two angled brace things connect. Not sure if this is truly the central rear point but that's what I found when doing research initially.
      05-21-2015, 09:41 AM   #10
trevor
Drives: 2005 BMW Z4 and 2001 BMW 515i
Look under the car, you'll notice parts of it are composite plastic, and part of it will seem metal under the doors, closer to the tires (and sometimes in a depression, like a trench) - that is where you want to mount up the car.
      05-22-2015, 03:37 PM   #11
wayne_zpost
Drives: 2010 Z4 (E89)
Rear lift point for 2010 (E89) Z4
I'm able to locate the jack stand slots next to each of the tires as well as the front lift point.
I've found a few images online for the rear lift point but none of them appear to be for the E89 Z4. If someone could post one it would be much appreciated.
Thanks,
Wayne
      05-22-2015, 03:45 PM   #12
jdoublehcubed
Mechanical Engineer
You're in the wrong forum for e89.
http://e89.zpost.com/forums/
