      12-14-2015, 10:26 AM   #1
Knoxes
Drives: E86
Rpm related noise
I have a 07 e86 with ~70K miles. I've had it for about a year and I notice this "whir" with the engine rpms sometimes - almost like a viscous fan. It's especially noticeable after I've been on the freeway for some time, and pull off. At the first rev after that, it's pretty predictable. It's not bothersome, but it does take away from the normal 3.0 engine grunt. I've searched a bit, but I haven't found any other threads (might be due to my search terms). Any ideas what this is?
      12-14-2015, 10:35 AM   #2
nate96
Drives: TI Silver 06 Z4 Coupe
I have this as well. It is the heater fan for me. If I turn the fan off the noise goes away, if I turn the fan to full blast for 5 seconds and then back to auto it goes away. If the fan is set to auto when I start the car it will "whirl" with motor RPM.
      12-14-2015, 01:14 PM   #3
Knoxes
Drives: E86
I would be surprised if it's the HVAC fan, but I suppose that it's possible. This sounds is very much tied to the rpms.
      12-14-2015, 01:51 PM   #4
nate96
Yes I agree. I was surprised. If I rev the engine the whirl from the HVAC would increase in direct correlation to it. If I turn the HVAC fan off it went away. Give it a try and see if that is what it is. The only explanation I can think of is the fluctuation in the voltage on the system on engine RPM. I see 12V at idle and up to 14.4V with the increase in RPM. I took my dash apart to get at the fan and it is a pain. I decided to live with this until the fan dies.
      12-15-2015, 11:05 AM   #5
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
I'm currently chasing something I thought was drive train noise on my wife's 328xi (also the N52). But....it goes away when I turn off the AC, which was a surprise-- so it at least appears the clutch on the compressor is effective.
Go ahead and try turning the AC switch on and off and see if it makes a difference.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      12-15-2015, 01:24 PM   #6
Knoxes
Drives: E86
That makes more sense to me. I can't say that it was more noticeable during the summer though. But I run the a/c almost year round to deal with the humidity.
      12-15-2015, 07:01 PM   #7
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
It could also be a worn alternator bearing.
Salty
      12-16-2015, 10:52 AM   #8
nate96
I tried this last night. As soon as I turned the A/C off the noise went away. I tried it a few times. I still don't get why the noise would go away if I turned the HVAC fan to max and then back auto.
      12-16-2015, 12:32 PM   #9
Karacticus
Karacticus's Avatar
I've got a service appointment on the 31st. If you don't find out what it is before then, I'll let you know.
It could be that cycling the fan from max to auto cycles the compressor, but really don't have any idea at this point. Too many computers. Does yours have the automagic climate control (set to temperature)? That's what I'm working with.
2007 3.0si Coupe
      12-16-2015, 12:39 PM   #10
nate96
Yes I have the automatic climate control. Let me know what they find out. It would be nice to get this fix and not deal with the sound anymore. It drives me a little crazy but no one else notices it.
      12-31-2015, 06:32 PM   #11
Karacticus
Karacticus's Avatar
Car was serviced today.
When I took the car in today, it wasn't making the noise as it was before, but then it's the A/C, and it's now 20F outside.
The tech did say that in the past, they've found similarly (written up, anyway) noises to be due to a low refrigerant level. They did find the system fill down to 8 oz, when the spec is 21 oz.
System was evac'd and refilled. We'll have to see if that addresses the issue or not.
2007 3.0si Coupe
      02-11-2016, 10:01 AM   #12
Knoxes
Drives: E86
Mine is worse now that it's much colder outside. It's not the HVAC fan or the a/c compressor.
      03-09-2016, 01:19 PM   #13
Knoxes
Drives: E86
I heard the fan spinning down after turning the motor off today. Since I had the A/C on, I'm assuming that was the aux fan.
It wasn't the same sound that I've been hearing. I'm beginning to wonder if it's the water pump bearings because I'm filling the reservoir with about 1-2 cups of coolant every 3-4 months. Maybe it's slow leaking?
      03-09-2016, 02:52 PM   #14
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Pull the serpentine belt and see if the noise goes away. Turn each component by hand and check for resistance. get a stethoscope and listen to each item running off the belt.
      03-09-2016, 06:28 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS. Could be an idler or belt tensioner pulley.
These are a common wear item, and chatter when they get floppy.
Check the AC tensioner, too, although I think it's less common for those to go floppy than the main belt tensioner.
      03-10-2016, 08:27 AM   #16
Knoxes
Drives: E86
Won't that throw a bunch of codes?
      03-10-2016, 11:28 AM   #17
longress
longress's Avatar
No there's nothing driven by the Serpentine belt that can trip codes (the battery light might come on). This is just a pull the belt, start the engine and see if the noise is gone and then check everything that is driven off the belt by hand.
You obviously don't want to run the engine long because the water pump and alternator won't be turning but it's not a concern if only done for a couple minutes
      03-11-2016, 08:03 AM   #18
Knoxes
Drives: E86
I thought there would be other sensors tripped by the lack of a belt. I don't have a shop manual - which tensioner is easier to access?
      03-11-2016, 09:37 AM   #19
longress
longress's Avatar
There's only one for each belt. The main belt has a plastic cover that needs removed covering the torx or hex (can't remember). Swing the tensioner down to create slack to pull the belt. Pull the belt over the alternator pulley to remove and when reinstalling the last pulley the belt is slid over is that same pulley. Make sure you draw a diagram of how the belt is routed.
I know what you're saying now. The other pulley is an idler pulley. The tensioner (lower pulley of the two)you can see has the ability to move the idler does not. Sorry if that sounds dumb ��
      03-11-2016, 09:52 AM   #20
longress
longress's Avatar
Here's a photo. If you google Z4M Drive belt and look at images it's all there.
      03-11-2016, 01:05 PM   #21
Knoxes
Drives: E86
Yup, got it. Thanks, longress.
I freakin hate getting underneath this car.
      03-11-2016, 01:20 PM   #22
Clearancediver
Drives: 2004 Z4
I drive mine up on low ramps... That gives me enough room to do a oil change. It also gives you peace of mind.... Nothing is going to collapse.
But agree with you about not liking going under the car.
Sent from my smart phone...
