      03-14-2011, 06:13 PM   #1
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Does anyone kow what this code means? help?!
p110d
this code came up yesterday...
      03-14-2011, 07:39 PM   #2
babydevilj
Drives: e46 M3. Z4 3.0i
P110D Throttle Position Sensor A and B Range/Performance. does your car idle funny?
      03-14-2011, 08:01 PM   #3
Z4-VILLA
Afghanistan
111
idling is fine accelaration is weird and jerks and bucks at 3k
      03-14-2011, 08:03 PM   #4
Z4-VILLA
Afghanistan
111
whats the part number to fix that?
      03-14-2011, 08:18 PM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
I am almost, but not totally sure, that the dealer must calibrate the new sensor...
I think it is item two (2).
http://www.realoem.com/bmw/showparts...11&hg=13&fg=15
or item three (3), same P/N.
http://www.realoem.com/bmw/showparts...03&hg=12&fg=10
      03-14-2011, 08:23 PM   #6
Z4-VILLA
Afghanistan
111
the problem occured imediately after gunning it one fine afternoon...
      03-14-2011, 08:24 PM   #7
Z4-VILLA
Afghanistan
111
hopefully Ocha will chime in
      03-14-2011, 08:31 PM   #8
Shipkiller
Shipkiller's Avatar
Drives: Me
Just pursuing through the TIS, here is a PDF on the basic adjustment procedure.
Ocha would have a much better explanation.
File Type: pdf RA Adjusting basic throttle setting (S54).pdf (664.1 KB, 1904 views)
      03-14-2011, 08:32 PM   #9
Z4-VILLA
Afghanistan
111
yeah i just pm'd him
      03-14-2011, 08:35 PM   #10
Z4-VILLA
Afghanistan
111
i wish i had the tools
      03-14-2011, 08:40 PM   #11
fr8tdog
International Bar Hopper
fr8tdog's Avatar
25
Drives: 2006 Imola Red Z4 M Roadster
I bet Ocha has the answer I'm surprised the car hasn't gone into limp mode with a TPS error. Didn't you have an air/fuel error code before? this might be fuel pump or filter because of load induced stutter. I would think a TPS error would cause limp mode...from previous experience. I bet it's a fuel delivery problem...be careful with this one.
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
      03-14-2011, 08:44 PM   #12
Z4-VILLA
Afghanistan
111
yea im glad this happened RIGHT before all the mods : euro headers, euro cats, valve adjustment, Oem clutch, CDV, Short Shift Kit, i was just about to have it all dont this week or next but now I have to focus on this....
i think Im gonna start with the fuel pump then lines then the regulator and pretty much do this carefully....
i guess p11od can mean plenty of things...
      03-14-2011, 08:46 PM   #13
Shipkiller
Shipkiller's Avatar
Drives: Me
Tools can be bought....
      03-14-2011, 08:56 PM   #14
fr8tdog
fr8tdog's Avatar
25
exactly! codes with generic descriptions don't tell the whole story. I would assume the worst...maybe a fuel delivery problem which is lean, which is very bad.
      03-14-2011, 09:50 PM   #15
Z4-VILLA
Afghanistan
111
I'm gonna have a more in-depth look tommorow
      03-15-2011, 02:01 AM   #16
babydevilj
i see your in the queens area. i have a mechanic about 20 minutes from your area if you want him to check it out. His name is Bill Rudtner. he only deals with Bmws and Porches. He has brought my m3 back from the e.r. many times.
      03-15-2011, 06:34 AM   #17
Z4-VILLA
Afghanistan
111
ok....i just googled him....found him.... thanks
