      04-26-2017, 08:27 AM   #1
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Lightweight Flywheel?
Gday all,
Just wondering if anyone here has any experience with the lightweight flywheels, are they a worthwhile investment?
cheers
Powered by
      04-26-2017, 10:09 AM   #2
Steeler
Steeler's Avatar
2429
Originally Posted by Vanne View Post
Gday all,
cheers
Hey Vanne, check out pokeys posts. He has a LWF on his non M. Different set up but likely similar experience.
Edit
Here it is http://www.zpost.com/forums/showthre...eight+Flywheel
Vanne1620.50
      04-26-2017, 11:12 AM   #3
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Not in this car, but went with one in the last car when upgrading the clutch to stage 2.
They "chatter" a lot. It can get really annoying and embarrasing if you like to have a car that sounds good and put together.
If you're focus is a drivers car or track car and noise or rattle doesn't bother you then you will love it. It makes a motor rev rise and drop so much quicker, making for such a great feel and personality to the motor.
Vanne1620.50
      04-27-2017, 04:04 PM   #4
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
UUC makes a really solid couple of options Vanne, when I got to drive mine it was a blast in feel. Very different, especially between Kevlar clutch and the flywheel. They don't lie though, they do rattle. However with your tune from Randy you can just raise the idle up and it will solve the problem. I needed to set mine right around 850 and it was just as quiet as stock. You already have the other tools to complete this mod, it just depends on how far you'd like to take it and if you can get by with a higher idle.
◙ Shane
Vanne1620.50
      04-27-2017, 04:26 PM   #5
3GFX
3GFX's Avatar
Originally Posted by Arsonism View Post
...However with ...[a] tune ... you can just raise the idle up and it will solve the problem. ... set mine right around 850 and it was just as quiet as stock. ...
Noted and considered!
Arsonism158.00
Vanne1620.50
      04-29-2017, 01:10 PM   #6
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks for the info and comments guys.
Powered by
      05-03-2017, 08:38 AM   #7
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
They did one on this car and are very happy with it.
Video from /DRIVE of their Z4M
