      10-15-2008, 07:13 AM   #1
symesz4m
symesz4m's Avatar
Australia
Drives: 2006 Alpine White Z4M Coupe
Wheel offset and their look
Hi guys
I am still trying to get my head around how offset effects the concavity of the csl wheels, if it does at all that is.
I want to get a set of csl wheels be it genuine or replicas or even a wheel like the Morr vs7 that have a decent amount of concavity, however I dont know whether the higher the offset the more concave or the lower the offset the more concave.....could someone please advise.
Cheers
      10-15-2008, 08:49 AM   #2
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
181
Drives: Z4M
the lower number offset the more concave. 22 is more concave than 23
      10-15-2008, 08:58 AM   #3
Incompatible
Drives: 07 AW Z4C 3.0Si
There is also a lot of variation in the design of the wheel. Two wheels of the same offset can have a big difference in their appearance. Aspects such as lip and concave/convex can be different between one style and another as well as between different widths of the same style wheel. If you want a certain look, you've got to see the wheel in the offset and width which is correct for your car. GL
      10-16-2008, 02:09 PM   #4
BMW F22
BMW F22's Avatar
Drives: ///M235i
Agreed. The smallest number usually means the most concaved. We carry the Velocity Motoring CSL wheels in the Z4M offset on our site if you're interested.
      10-16-2008, 02:18 PM   #5
GooDy151
GooDy151's Avatar
No_Country
20
Drives: BUS
Also it depends on how wide the wheel is too.
22ET for 9.5" wide is not concave as 22ET on 8" wide
'09 Z4 35i on the way of build
'06 997s built motor from Vision Motorsport 421WHP N/A
'96 Skyline R33 GTS stock trying to register it.
'99 Subaru Impreza 2.2 JE pistons , HKS rods , Jun cam 272 / 272, Greddy T78 32D , Sard 1000cc Inj., Tein and Tomei SQ trans , 10.21sec
      10-16-2008, 07:17 PM   #6
AtoB
AtoB's Avatar
Drives: Z4M
i have 22ET 9.5 x19s on the rear.... they sit right flush with the wheel well.
A
      10-16-2008, 08:06 PM   #7
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Offsets don't tell the whole story. It has more to do with a wheel's styling.
The authentic rear ZCP's/CSL's with -27 offsets are more concave than the CSL replica with -22 offsets.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      11-02-2008, 08:42 PM   #8
nlink720
Drives: 2004 BMW Z4 Roadster
http://www.1010tires.com/WheelOffsetCalculator.asp
      11-05-2008, 04:02 PM   #9
modbargains
modbargains's Avatar
170
Drives: 08 E90 335i & 01 Toyota Avalon
Wheel concavity depends on width, disk type, face, and offset of course. Generally the lower the offset more concave it will be but that is not the final determining factor.
