01-30-2011, 10:52 AM | #45 |
Rep 2,120
It would have to be an LED
From what I understand I will be able to tell the car not to issue the "light out" warning lamp for LED's being used so yes thats a possibility,
Imola Red Roadster |
01-31-2011, 06:58 AM | #46 |
Rep 12,565
Do you happen to have the specs for the type of bulb that's currently in there? Maybe I'll buy both, a LED and a whiter H7 or H11 (whatever's in there) and see which works / works best?
01-31-2011, 11:30 AM | #47 |
Rep 243
Let me know when your up and running
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress |
01-31-2011, 12:35 PM | #48 |
Rep 12,565
after reading this, i may stick with the stock bulb. i don't mind getting my hands dirty but like you said, LED -> error code, and 20w bulb is marginally better, and not sure how sustainable it is in the long-run if it gets too hot.
http://www.bimmerfest.com/forums/sho...d.php?t=417609 i'd risk it if the outcome was much better looking but doesn't seem worth it in my opinion. jamie let me know what day works for you. i'll just stick to amber delete & nav accept off. |
01-31-2011, 04:58 PM | #49 |
Rep 2,120
Yeah I don't think upgrading the bulb would work out
TBH it looks a lot brighter without the amber surrounding it anyway, you can clearly make out the ring when you do the euro coding and delete the amber, Should be all setup either this week or next,
03-29-2011, 06:08 PM | #51 |
Rep 1
Hi Starscream
Are you up an set for remapping of the LCM to Euro program. I have imported Z4 3,0si 2008 from US, and need the convertion from US amber to Euro White, to get the registration here in Norway. |
05-06-2011, 12:52 PM | #52 |
Rep 243
R U up and running yet?
06-04-2011, 07:43 PM | #54 |
Rep 243
Any chance you will be able to do this for our cars????
08-12-2011, 12:50 PM | #56 |
Rep 6,863
Thought I would give this thread a bump as I need help.
I just went to a local shop to see if they could euro code my m coupe. The tech told me that its possible but he needs to know what configuration to change. For example, if the car read H343L5317 he would need to know which characters represent the lighting system and what to change it to. So if in my example the "L53" represented the lighting system he could change it to "L52" or whatever the european code is. Does that make sense? Help is appreciated! |
08-12-2011, 02:43 PM | #57 |
instagram 997turbotom
279
Rep 7,377
10101110101010101010111101010101011101010101010101 11101010101011101010101010101111010101010111010101 01010101111010101010111010101010101011110101010101 11010101010101011110101010101110101010101010111101 01010101110101010101010111101010101011101010101010 1011110101010101110101010101010111101010
heh
08-19-2011, 08:06 AM | #60 |
Rep 102
According to THE SPREADSHEET its in the FRM/NFRM module the function value is SIDEMARKER_US_* and the value to change it to is "nicht_aktiv".
Check yourself: https://docs.google.com/spreadsheet/...CPqY7sEC#gid=0 |
08-19-2011, 07:46 PM | #62 |
Rep 102
I could imagine their coding system is a little different. However, the words for "not active" in German probably aren't going to be any different. Worst that can happen is you look for the particular code in that module and it's not there.
08-31-2011, 08:47 AM | #63 |
Rep 12,565
Bump, so I found out that our cars need an adapter on the end of the cable - the same one used for e46's (unlike the e90's). By using this adapter, the software is able to communicate with our cars (last time I attempted this, I was't able to get the software to recognize the DME).
So my next question is, what are the actual settings to delete the amber strip? I played around with a few, and I was only able to get rid of the middle bulb, but still had amber light up on the ends. Jamie, anyone? |
09-08-2011, 05:51 PM | #65 |
Rep 2
hello
can anyone help me i am from europe and i messed up my lcm with the beta version of nav coder now i have amber lights and my stop lights witch they are round only light up half , and my dimmer dosent work, and i want the one touch convertible thx
12-18-2012, 05:34 PM | #66 | |
Rep 439
Starscream, whatever happened with this?
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
