      02-13-2015, 09:12 AM   #1
SCZ4
Drives: F11 525d M Sport & Z4M
///M Front Lower Wishbone Rear Bush Options - Lollipop
Hi Guys,
As part of my owning maintenance, now at 60k miles, to freshen things up I'm going to the replace the above bushes. From the searches I've done, no one in the UK offers Poly style bushes her in the UK. Is this the same for you guys in the US?
I can get new BMW bushes and the metal lollipop for about £110 delivered, saves messing around burning out the old bushes and pressing in the new ones.
The Z4M bushes have an eccentric fitting, so can't fit the poly bushes available for the E46 M3. In fact from the looks of it, many E46 owners fit the Z4M bush as an upgrade to get more castor.
So just before I order from BMW, any other options? Don't mind importing, I have Rogue rear trailing arm bushes that I imported, but they don't have anything
G
      02-14-2015, 03:54 AM   #2
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
SuperFlex. Sourced from the UK. A few of us are running these and happy with them. Don't have the link but you should be able to find a few threads on them if you search.
      02-15-2015, 03:03 AM   #3
SCZ4
Strange, I contacted them and they said no for the ///M, website also says the same. Was it a special order?
"The Front wishbone bushes will not suit the Z4M Models "
http://www.powerflex.co.uk/road-seri...29-1203/1.html
      02-15-2015, 05:42 AM   #4
GuidoK
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
That is powerflex.
Superflex is a different brand.
These are the ones:
http://www.superflex.co.uk/proddetail.php?prod=
SF095-2558K is the p/n
They are not originally made for the z4m but are a e46 66mm offset bushing (comes down to the same...)
This is the thread (was originally a thread for rogue bushings):
http://www.zpost.com/forums/showthread.php?p=13214890
(a few posts down there is a link from an ebay seller, dont know if he still sells&ships)
      02-15-2015, 05:48 AM   #5
SCZ4
Ah perfect!! Apologies for misreading the post. I hadn't heard of supeflex and automatically thought Powerflex.
Great, so those are effectively eccentric bushes with the 66mm "double offset"?
      02-15-2015, 11:20 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I've been running these for a while now, they work great.
Here is my install comments.
http://www.zpost.com/forums/showpost...&postcount=152
