04-20-2023, 10:29 AM | #1 |
Rep 1,770
Drives: Bmw 330i and Bmw 328i
Low coolant
Every now and then after a 120 mile drive my coolant gets a bit low. As in the bobber in the resivoir goes low but I still see coolant in res. I have been topping up with distilled water for the pass 1200 miles. Is this okay? Will it hurt anything? I live in Socal so it gets hot here anyways. And lowest temps at night have been 51.
04-20-2023, 10:41 AM | #2 |
Rep 562
Did you ever check the expansion tank out? It’s not normal to go through that much coolant no. You’ve got a leak somewhere if the tank has never been replaced that’d be my first go to to pull and replace as piece of mind anyway, wouldn’t hurt to do complete coolant system refresh. If you’ve got a pin hole leak in there you may not see the drip. Is there any residue on the plastic cover underneath? Bhg aren’t unheard of now on the m54 but only if it’s really been abused otherwise not common but how's your oil look?
2one3E902422.00 |
04-20-2023, 10:53 AM | #3 | |
Rep 1,770
04-20-2023, 11:15 AM | #4 | |
Rep 562
The danger is you could be introducing air into the system if you’re not bleeding it out every time you’re topping off. The m54 is easier to bleed, just raise front end ie ramps and idle at 1500rpm till you don’t see any air and it’s a fluid stream coming from that small left hole inside the tank I mentioned. But over all it sounds like you need to do a coolant system refresh. Hoses can take a toll if you’re getting air into the system. I didn’t bleed out good enough on my 87 Supra and blew the old hoses after a radiator replace once. Not fun lol. Do it right. If you know the rad is leaking replace that, hoses and the tank at the same time. Edit: just to add crank inside thermostat hot and on high when doing it. I know there’s how tos here and on the z4-forum for the m54 bleeding procedure but very easy and straight forward. Last edited by Piper1; 04-20-2023 at 03:08 PM.. |
2one3E902422.00 |
04-20-2023, 11:24 AM | #5 | |
Rep 1,770
04-20-2023, 05:42 PM | #6 |
Rep 2,547
Just so you know, there's a lot more properties to anti-freeze than the freeze prevention part
Always top off with 50/50 mix of BMW coolant and distilled water, no matter how warm of a climate you live in. Last edited by pungo; 04-25-2023 at 10:19 PM.. |
04-22-2023, 08:38 AM | #7 |
Rep 47
. . . .getting the front end up on ramps is still great advice for the z4's with N52 engines (LCI, aka Facelift). Those cars have electric water pumps and auto-bleed, but on my car, two auto-bleed's left trapped air until I put the nose up.
Mariner Z4C
2006 Z4 Coupe 3.0Si, Montego Blue, MT 2008 128i Convertible (sold) 2005 325xi Sedan (sold) |
