      06-22-2022, 12:43 PM   #1
mothy5000
mothy5000's Avatar
Drives: '08 BMW Z4 3.0si E85
Bulb Out Warning Dash Light Won't Go Off
My bulb out warning dash light came on about a year ago due to my xenon ballast failing and a brake light going out. I have fixed both of them and the dash light is still on. No codes are showing up in my code reader. (I thought all dash lights were tied to codes.) Can this be fixed with iCarly?
Thanks for any advice on this!
      06-22-2022, 12:47 PM   #2
pungo
pungo's Avatar
Did you use inpa or ista to read the codes? If not, do that first.
      06-22-2022, 04:35 PM   #3
wdb
dances with roads
wdb's Avatar
4732
Every time my bulb out light came on, I had a bulb out somewhere. Could be a turn signal...
      06-22-2022, 10:32 PM   #4
mothy5000
mothy5000's Avatar
All interior and exterior lights are working.
      06-23-2022, 06:34 AM   #5
TF07Z430i
Drives: 07 BMW Z4 3.0i roadster
Check your halo bulb around the headlight. It is easy to miss. Mine went out and took me a month to figure it out. You may need to do it in the dark to really see if it is working.
      06-28-2022, 01:35 PM   #6
mothy5000
mothy5000's Avatar
Both halos are working as I replaced those myself about a year ago.
      06-28-2022, 01:37 PM   #7
mothy5000
mothy5000's Avatar
Will this tell me which bulb is causing the dash light?
      06-28-2022, 02:06 PM   #8
pungo
pungo's Avatar
Most likely.
      06-29-2022, 03:51 AM   #9
mmm-five
mmm-five's Avatar
Drives: 2006 Z4MC + 2015 320D M-Sport
Have you replaced any with LEDs?
I did this to my halos and had to code out the bulb check.
      06-30-2022, 10:10 AM   #10
mothy5000
mothy5000's Avatar
No LEDs. All original.
      06-30-2022, 01:34 PM   #11
Clearancediver
Drives: 2004 Z4
The dash warning light is indicating that one of your bulbs is going to fail…. Warning lamp doesn't need a "failure" to actuate…..
I had a program that would indicate approximately which circuit…but not which light exactly. In sure that INPA and ISTAD are capable of doing the same.
Sent from my smart phone...
3002 tii2285.50
      04-18-2023, 11:15 AM   #12
OliverCarrillo
OliverCarrillo's Avatar
Drives: Toyota
The warning light may still be on because the car's computer system needs to be reset to clear the warning. Try disconnecting this battery for a few minutes to see if that helps reset the system. If that doesn't work, there may be a separate issue causing the light to stay on. If it is something wrong with the light bulb, I suggest getting another one (the prices are reasonable here www.greasemonkeydirect.com/pages/bulbs). I hope that helps!
      04-18-2023, 07:43 PM   #13
pungo
pungo's Avatar
Welcome to the forum....
Sorry, but just so you know, that's not how it works
