01-17-2015, 12:52 PM | #1 |
Why so serious?
141
Rep 743
HELP! Passenger side HID does not work
Hey guys,
My passenger side HID does not work. The DRL does. I've tried new bulbs on both sides. I've also swapped the ignitors around and it works on the driver side but not the passenger side. So, the bulbs and the ignitor are ok. Checked all the fuses behind the glove box, all lighting fuses are good. What could be the issue? Thanks Last edited by SwissArmy; 01-18-2015 at 07:43 AM.. |
01-17-2015, 02:40 PM | #2 | |
Rep 758
Top Down 365
01-17-2015, 02:42 PM | #3 |
Why so serious?
141
Rep 743
01-17-2015, 05:04 PM | #4 |
Rep 758
Need to check 14, 23, 59, and 60.
Top Down 365
01-17-2015, 09:30 PM | #5 |
#dubspec
6331
Rep 5,201
its your ignitor
01-17-2015, 09:31 PM | #6 |
#dubspec
6331
Rep 5,201
silver box that hold your bulbs
01-18-2015, 05:55 AM | #7 |
Why so serious?
141
Rep 743
01-18-2015, 05:56 AM | #8 |
Why so serious?
141
Rep 743
01-18-2015, 06:34 AM | #9 |
#dubspec
6331
Rep 5,201
Ok. You mentioned u swapped the ballast not the ignitor
01-18-2015, 09:11 AM | #12 |
Rep 400
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
01-18-2015, 09:39 AM | #13 | |
Why so serious?
141
Rep 743
http://www.ecstuning.com/Search/Wiring/ES165766/ |
01-18-2015, 10:35 AM | #14 |
Rep 400
You can also check for continuity between pin 34 and ground (the right headlight) at the headlight switch with the switch to ON and see if you get the same reading as pin 7 to ground (the left headlight). If you don't have continuity on the right and do have it on the left, you might need a new light switch.
Go to BMW Planet.com for a drawing of the circuit. It's under complete vehicle/ body/ lighting/ low beam light. Can't cut and paste this one right now.
01-18-2015, 10:47 AM | #15 |
#dubspec
6331
Rep 5,201
what you could do is swap the headlight and see if power from the opposite side fires up the headlights. it could be the ballast now
01-18-2015, 06:55 PM | #16 | |
Why so serious?
141
Rep 743
Thanks. Will try this and report back |
