08-04-2008, 08:08 AM | #1 |
Rep 127
Z4si and Z4M Aesthetics
I'm curious what all is aesthetically different about the si coupe vs. the M coupe. I know the front bumper, hood, and quad exhausts are different, but there's something about the way these cars photograph..sometimes one might look a little stubbier than the other, sometimes they appear to have the same contours. Do the ridges on the hood change the hood's contours on the M, or is it just my imagination? I've never been able to do a good side be side comparo of the two coupes in person.
08-04-2008, 08:26 AM | #2 |
Rep 2,120
Ive had both and the look of the M in photos is night and day,
the non M hood almost makes the Z4 look boat like in the front, The lines in the M bumper change that and look great from the driving perspective too, The M bumper makes the front end look "chunky" esp how it hangs down with its "fangs" the back looks great too with the quad tails and the diffuer at the bottom of the bumper, It takes the sweeping look away from the non M bumper, In all I think the only thing the M is missing stock is the Aero side skirts and I think they should have come stock on the M to complete the body transformation Non M's still look hot though
Imola Red Roadster |
08-04-2008, 08:31 AM | #3 | |
Rep 15,081
Drives: '16 M2, '23 GT4
Nice save. Isnt the suspension setup differently as well? Making the M look wider?
IG: Trackinheels
08-04-2008, 09:27 AM | #6 |
Rep 1,224
There's no mistaking the dual exhaust of the M. Mods will change the look in a subtle way for both the M and non M, but there is nothing subtle about the difference in the exhaust.
08-04-2008, 12:16 PM | #7 | |
1821
Rep 5,337
What is also surprising is the Si Coupe is actually LOWER than the MZ4 Coupe. The overall height of the Si Coupe is 49.9", while the MZ4 Coupe is 50.67" high. Otherwise the wheelbase and overall length is the same. I'm not even entirely certain the M has more negative camber. Prior to adding camber shims and knocking out the alignment pin up front, the stock front camber was only -1.4 degrees and the rear camber was -1.3 degrees, which is pretty close to the typical BMW negative camber settings. |
08-04-2008, 01:32 PM | #8 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
The Mcoupe DEFINATELY has a wider track in front.
08-04-2008, 01:58 PM | #9 |
180
Rep 1,471
dont remember where i read the wider track but it would make sense. defiantly from a liable source though. ill search around for it. about camber the rear camber for Z4M is between -1.6 to -2.1. the fronts im not too sure.
if they do have the same track then it would be possible to make the Z4 as stiff as the Z4M by just adding wider tires and new suspension. something doesnt sound right. im going to askl palatirion to come and chime in. |
08-04-2008, 02:28 PM | #10 | |
Rep 15,081
but i think someone had posted otherwise when i made a thread about suspension... ill look for it
IG: Trackinheels
08-04-2008, 02:49 PM | #11 | |
1821
Rep 5,337
As for the front track of the MZ4 Coupe being wider, BMW's own numbers and measurements suggest otherwise. See diagram attached. Not saying BMW NA is the end-all, be-all source (they've made mistakes in their press materials in the past), but right now I'm inclined to believe their numbers since it's the only source I have to go by. EDIT: Now that I had re-read the thread I think you mean to make the Z4 Coupe Si's suspension as stiff as the MZ4 Coupe. The problem in assuming that, is the MZ4 Coupe's front and rear suspension design is completely different than the Z4 Coupe Si. You can add aftermarket suspension to make the Z4 Coupe Si handle just as good or better than the MZ4 Coupe, there's no denying that. You can not, however, make the MZ4 Coupe suspension work on the Z4 Coupe Si since almost all of the mounting points and geometry is different. The MZ4 Coupe uses a customized front suspension from the E36 M3 and a nearly complete carry-over of the rear suspension from the E46 M3. The diff carrier, trailing arm, upper control arm, rear subframe, lower control arm, will need to be replaced for the Z4 Coupe Si to take the rear suspension from an MZ4 Coupe, and I don't think the front suspension can be made to work on the Z4 Coupe Si at all. |
08-04-2008, 02:55 PM | #12 |
1821
Rep 5,337
08-04-2008, 03:03 PM | #14 |
1821
Rep 5,337
08-04-2008, 03:29 PM | #15 | |
Rep 5,069
"...The front track is a half-inch wider than the Z4's, the forged-aluminum lower control arms locating the bottom end of the struts are essentially the same as those employed in the M3..." http://www.caranddriver.com/reviews/..._test/(page)/1
08-04-2008, 04:01 PM | #16 | |
1821
Rep 5,337
E86 M4oop http://www.realoem.com/bmw/showparts...79&hg=31&fg=05 31122282121 Left wishbone 31122282122 Right wishbone E46 330i http://www.realoem.com/bmw/showparts...00&hg=31&fg=05 31122282121 Left wishbone 31122282122 Right wishbone E46 M3 http://www.realoem.com/bmw/showparts...76&hg=31&fg=05 31122229623 Left wishbone 31122229624 Right wishbone Now, the ZHP LCA is a little bit wider than the normal 3 series LCA, but we can't just assume that because the LCA on the M4oop may possibly be wider than the Si Coupe that it means the M4oop front track is wider. We have got to keep in mind that the rest of the M4oop front suspension is so different from the Si Coupe that other factors may make it so that the front track ends up being the same width after all. There's still no confirmation that the M4oop is indeed wider unless we can get one to measure against an Si Coupe? EDIT: There's nothing online that should ever be taken as "common knowledge." |
08-04-2008, 04:33 PM | #17 | |
Rep 5,069
I can already tell you are never wrong, but here you go. Take it or leave it. These are the numbers from BMW's international website. These measurements are more accurately reported in mm's rather than the rounded inches used in the bmwusa site. Works out to ~1/2inch difference.
08-04-2008, 04:41 PM | #18 |
Rep 5,069
Here's the math: 1473mm/2.54cm=57.99in vs. 1486mm/2.54cm=58.50in
08-04-2008, 04:52 PM | #19 | ||
1821
Rep 5,337
Now that it is proven that the front track is indeed wider, I guess you OWN me and I should probably just shut the hell up and never post here again. Sorry for the inconvenience. And C&D is indeed wrong. The E46 M3 LCA is very different in design to the E46 330i ZHP and MZ4 Coupe LCA. |
08-04-2008, 05:38 PM | #20 | |
Rep 5,069
08-04-2008, 06:15 PM | #21 |
Rep 385
-Any idea what the torsional rigidity #s are for other Z4 M competitors?
08-04-2008, 07:08 PM | #22 |
Rep 15,081
hey guys, dont stop posting... its good that we finally have people actually discussing Z/Ms!!
IG: Trackinheels
