08-20-2010, 11:31 AM | #1 |
Rep 632
Recommend fixes for fender liner rub
Hey all - my brand spankin' new wheels and tires just barely fit. I haven't got a ton of mileage on them yet, but up front I noticed some tire rub during heavy suspension compression with a big dip in the road. Pics below. I haven't noticed rubbing at any other time yet. On a scale of 1 to 10 with 1 being a minor road imperfection and 10 being a massive, big dip in the road, I'd say the one I went through to get this rub today was probably a 6 or 7.
What have people done to limit this and preserve the fender liner? Selling the wheels and tires is my last option if at all possible - it's one set of about 30 that were made and I waited like 4 months for them. Oh, and I'm hoping to put dinan springs on for a slight (very, from what I understand) drop on the car - so that makes me more worried about the rubbing. Any and all solutions that you've seen used, preferrably on the Z4 but on any car, might help. I've heard about this heat gun trick with the plastic - elaboration on that would be great.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
08-20-2010, 03:36 PM | #4 |
Rep 1,855
Can you go lower profile? You wouldn't have to get rid of the nice rims. Maybe a little camber would help? It only looks like your tires are rubbing at the inner edge. If you can tuck your tires in slightly with a little camber, maybe it'll stop rubbing.
Dinan springs are supposed to drop you 0.5 inches, which isn't that noticeable, but will definitely exacerbate that situation.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
08-20-2010, 06:53 PM | #5 |
Rep 1,143
Camber probably won't move the top more than a few mm or so unless you go HELLA FLUSH, which is about as classy as underbody lighting. It would probably still help a little though.
Going lower profile will probably reduce diameter close to an 1", which is pushing the limit of tolerable deviation from spec for speedometer/odometer readings. Would the width of your wheels accept 10-20mm narrower section width tires without looking stretched out? |
08-20-2010, 08:56 PM | #6 |
Rep 341
Sorry to hear they're rubbing.
Thinking about increasing negative camber using shims, how much clearance do you have now between the inside of the tire and the strut? I only have about a finger's width with my stock wheels and 225s. Might be forced to do it from the top . . . hello, camber plates! FG |
08-20-2010, 10:07 PM | #7 | |
Rep 632
255/40 18 - the fronts are an 18 x 9 et38 wheel. I wanted this size because it is identical to stock rolling diameter and, since these wheels have never been run on a Z4M before, I honestly didn't know of anywhere else to start. Since it's a front wheel, a smaller diameter tire wouldn't affect the speedometer however, what about traction control?
08-21-2010, 07:56 AM | #8 |
Rep 1,373
My suggestion is go for a 255/35 front tire. That is what I run and I don't have any rubbing issues. If you combine the 255/35 tire with a tad more camber I don't think you would have any more issues
07 Z4 M Coupe AW/IR |
08-21-2010, 09:03 PM | #10 |
445
Rep 1,658
add negative camber. don't shim. Get plates. If you don't want a full race plate like Vorshlag, then Get Dinan fixed plates if you're going to get their springs. Your wheels et38 offset is a bit too aggressive for a 9" wheel, which pushes out that tall 255/40 tire. 245/40/18 would have been a better front choice for the correct overall diameter and with no rub, or 255/35/18 since a 1%~ decrease has zero effect on any of the cars systems, or even visually.
08-21-2010, 09:22 PM | #11 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
08-22-2010, 12:47 AM | #12 |
Rep 1,143
08-22-2010, 11:27 AM | #13 | ||
Rep 632
It's not just anywhere near, it is almost exactly the same rolling diameter. Width are different, but I wasn't talking about the widths. Since these front wheels are 9" wide, same as stock, I decided to go with a stock size rear tire. Didn't expect rubbing - I was not told to be concerned about it on the initial purchase. If I'd known, probably would have done a 255/35 or 245/40 instead of the 255/40, like a stock rear. Despite all this, smaller tires or using a heat gun on the inner fenders, I think the front 9" wheel is probably too much for the Z4M. Like I said, I'll be getting some pics up soon - please take a look and make comments. I'm honestly just looking for some opinions on fitment appearance. Essentially, I'm 99.9% sure I can sell them on the E46 M3 forum and from the get go, I knew this might be a gamble for the Z4M. So, it's a matter of how badly I want to make them work I guess. More to come - thanks so far guys!
08-22-2010, 07:15 PM | #14 |
M = Midlife Crisis
65
Rep 2,006
It's the width causing the problem when you turn the wheels...
09-02-2010, 08:08 PM | #15 |
Rep 1
Is rubbing common on standard rims at full lock?
I have a stock standard Z4 M Coupe on standard 225 front rims and the front right tyre especially rubs when the wheels are at full lock right hand down. Is this a common problem/wat is causing it/ how can i fix it?
09-02-2010, 08:29 PM | #16 | |
Rep 11,668
Just use a heat gun on the low setting to warm up the liner. When it gets soft just bend it back inwards a little. I did this with my previous M Roady, worked like a charm.
09-03-2010, 09:28 AM | #18 |
Rep 208
Same here...once it rubs through you should be good. As long as the bolts are in to hold up the front bumper you should be fine. I have -3.5 camber on tck d/a's and I get rub with 18x8.5 245/40 toyo ra1s when I track.
BONE STOCK
09-03-2010, 09:43 AM | #19 |
Rep 11,668
I just don't understand why anyone would just let it wear through, when it's a 5 min fix.
IMO it doesn't make sense to have a crappy hole through the liner. As you can see the bumper edge leaves a lot of room to push the liner back a bit with a little heat.
09-03-2010, 12:58 PM | #20 | |
Rep 238
But its up to the individual owner. |
09-05-2010, 08:27 PM | #22 | |
Rep 632
This is definitely on my list as an option. Mainly because I plan to perhaps lower it a tad - Dinan springs, so it won't be much, if anything. I'm going to try to use a heat gun on the liners first, then do my springs swap, and see if I then need to reduce the tire size.
Are there any good ways to simulate full front suspension compression to test rubbing issues under compression? I don't think it's safe to place a jack under front suspension pieces to force compression. Is this something I could do when I do my springs swap?
