      04-01-2017, 05:33 PM   #1
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
Replacing the 6in subs behind the seats
Last week I had the passenger side subwoofer go out. It was making a terrible buzzing noise and no matter how I messed with the fading, bass, balance, etc it would not go away. Anyways, I went to order one from BMW parts and they quoted me $350 as an employee. Hard no to that.
I see that the sub is a phillips unit and looks pretty generic. Are there any after market options that would be somewhat plug and play to replace both subs behind the seats? If I am going to spend $350 I would rather get somewhat of an upgrade.
Thanks!
      04-01-2017, 05:57 PM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
The subs are not generic at all. They have a very uncommon impedance (10 ohm). Good luck finding that in the generic section.
These speakers can sometimes be found on ebay for an acceptable price.
Fitting aftermarket speakers would require a different amp which means you need a different amp for all speakers as its an integrated unit.
      04-02-2017, 02:20 PM   #3
SnapCoupe
BMW Portland
So does that mean there are no aftermarket plug and play options that will run off the stock amp?
      04-03-2017, 11:17 AM   #4
ShakyDog
ShakyDog's Avatar
B-i-n-g-o, B-i-n-g-o, B-i-n-g-o and Bingo was his name-o.
Steve
      04-03-2017, 11:48 AM   #5
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
I was bored at work so I googled.
http://www.turnswitch.com/speakers.htm
http://www.daiichi.com.tr/en/product...odel-51740461/
      04-03-2017, 12:46 PM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10859
^those will be very poor subs
Certainly not a normal car audio woofer (4 ohm), you'll blow the amp for sure.
I dont know how an 8 ohm will perform (amp wise, will it blow up, get hot or go into a safe mode), but the other problem is: try and find a suitable 8 ohm sub (long throw) in that size and suitable for that enclosure.
I dont know if you know anything about speaker design (do you know what Thiele/Small parameters are and can you use them in calculations?), but not every speaker is suitable for every enclosure (both in size and enclosure type).
So the best way to go is to get a used speaker from ebay. They are plentiful and not expensive. Usually $30-60 ex shipping.
http://www.ebay.com/itm/2003-2008-BM...-/222407504163
http://www.ebay.com/itm/OEM-02-08-BM...-/262712200754
http://www.ebay.com/itm/bmw-e85-e86-...-/182499529689
etc
      04-04-2017, 02:38 PM   #7
SnapCoupe
BMW Portland
etc
This is what Im going to end up doing. I went to a few audio stores to see if they could rebuild/repair the sub, and I was quoted with $80-$120. I would much rather just get a used one. Does it matter which side it comes out of? Or do I have to specifically get a passenger side replacement?
      04-07-2017, 03:35 PM   #8
Beedub
Bavauto plug and play upgrade units?
      04-08-2017, 11:37 PM   #9
w3fl3x
...yummy...
w3fl3x's Avatar
Drives: M3, Z4MC
Try Bavsound? I know they have speaker upgrades and subs. Just never looked up for our z.
If I listened to music more often then I would use their speaker upgrade for my e46.
      04-11-2017, 10:20 AM   #10
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Subs are not side specific.
      04-13-2017, 06:11 PM   #11
SnapCoupe
BMW Portland
I know acoustically they are not, but bracket wise they look to be asymmetrical?
I just wanted to double check.
      04-15-2017, 08:56 AM   #12
brendanto
brendanto's Avatar
Drives: 2005 BMW Z4 3.0
I replaced both subs with JL Audio 6 in subs. Took a bit of modifications to fit them (I removed the sound insulation and put covered the opening with sound deadening mat). Had to call very the signals and amp. They sound better than the originals but can't get a lot of bass out of a 6" woofer.
      04-28-2017, 11:45 AM   #13
Eau_Rouge111
Eau_Rouge111's Avatar
Drives: 2009 128i and 2007 Z4M Coupe
I'm working on something myself. Going to keep the factory system as is but adding a 10" shallow mount sub in the trunk along with an amp to power it. I' building a custom battery cover to replace the current one out of 3/8" plastic then mounting a box to it for quick install and removal...the box is low enough to let the sunshade still work but big enough to give the minimum volume of 0.35 square feet the pioneer sub needs. Then attaching a line out converter to the speaker wires. Should be done in a month or so...taking my time so I get it right.
All this will be fully reversible other than tapping into the speakers for the Line Out Converter. So if I choose to put it back as is...
I'm by no means a music buff or anything like that...just the stock Z4m system in my opinion creates no base.
      05-01-2017, 01:44 PM   #14
elerner61
elerner61's Avatar
157
I think mine sounded better once I threw some fiberfill in both enclosures.
