06-29-2012, 06:01 PM | #596 |
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
Toyota & BMW to Develop Sports Car... who would thought about that?!
06-30-2012, 04:15 AM | #597 |
Rep 3,888
^ That could bring us some of the best sportscars in the world. Toyota and other Japanese have the best EPS in the world, the M3 could need it. Both BMW and Toyota are the most profitable and capable car companies in the world.
07-02-2012, 07:10 AM | #598 | ||
Rep 1,247
Levi, I'm sorry to say it but I think you are missing the point. The BMW E30 M3 was a 2+2 seat and it wasn't specially powerful in the US trim, at 192 hp (6750 rpm) with catalytic converter (83.5 hp /litre), for a 2735 lbs (1240 kg) car and yet it was the car that gave BMW's reputation for great everyday use vehicle dynamics, NOT some two-seater sports coupe . As Chris Harris has so well put it: Quote:
Of course that having a 2.3L displacement engine the E30 M3 had higher max. torque, 170 lb-ft (230 Nm @ 4750 rpm), further complemented by the small 205/55-15 tires. However, max. torque was available over a much narrower rpm band and the US overdrive gearbox had taller gear ratios (except 1st and 2nd) for the same final drive ratio when compared to the Toyobaru: .............. Toyobaru................ E30 M3 (US model) 1st............ 3.63:1................... 3.83:1.............. 2nd............ 2.19:1................... 2.20:1............. 3rd............ 1.54:1................... 1.40:1.............. 4th............ 1.21:1................... 1.00:1.............. 5th............ 1.00:1................... 0.81:1.............. 6th............ 0.77:1.......................................... Final drive... 4.10:1................... 4.10:1.............. The E30 M3 in standard trim had a maximum permissible continuous engine speed of 6900rpm (7000 rpm redline) and boasted 7.6s in 0-62 mph (not the 0-60 mph time as it is wrongly stated in the picture) and a top speed of 230 km/h or 143 mph with catalytic converter (235 km/h or 146 mph without a catalyst). Even the dimensions are basically the same for the Toyobaru and the E30 M3 as far as weight, weight distribution front/rear, wheelbase and overall lenght go: The S14 engine of the E30 M3 albeit canted over 30 degrees to the right lowering the center of gravity and balancing out the weight of the driver still had a significant 30 inch height when measured on a vertical axis and weighted 380 lbs (172 kg) fully dressed 'wet'. To give you a better idea of the meaning of that the S2000's F20C engine is a much more compact unit weighting only 326 lbs (148 kg) fully dressed and its height is 25 inch on the vertical axis with the engine canted over to the right by 15 degrees only: Also, it's not so much a question of power but torque. To give you an example, my 1M could well had a 5000 rpm redline and only 300 hp because that's where the BIG torque, hence max. acceleration, is and I don't feel the need to rev it higher. As you can see... the Toyobaru really is a cornerstone: Last edited by GoingTooFast; 07-04-2012 at 08:19 PM.. |
07-02-2012, 09:46 AM | #599 | |
Rep 1,247
Just want to highlight that the E30 M3 weight distribution front/rear was NOT BMW's self-proclaimed best 50:50, it was 53:47 instead.
So, Toyota and Subaru were right about their empirical experience: Quote:
Do you think it's coincidence?! I don't think so... |
07-02-2012, 11:42 AM | #600 | |
Rep 1,247
"Is Technology Making Cars Worse?"
No! Weight is! If every car brand CEO did as Akio Toyoda says he does... the focus would always be the driving experience (remember Ferry Porsche?!): Ferry Porsche: Quote:
07-02-2012, 12:37 PM | #601 |
Rep 697
Drives: M3 F80 silverstone
awesome car
will they make a sti version?
if you're cast on thin ice, you may as well dance
enjoy your cars |
07-02-2012, 03:23 PM | #602 |
Rep 1,247
07-02-2012, 06:01 PM | #603 | |
Rep 1,247
BMW Rep Says Toyota's Sports Car will Have a Unique Design, Insider Hints at 6-Series-Based Supra
07-03-2012, 02:38 AM | #606 |
Rep 3,888
That is why I keep repeating what I say. It has been some years I taked about renaming the 1 Series and 3 Series Coupé/Convertible to 2 Series and 4 Series. A 6 Series based Supra will never exist, you can be sure of that. Look at the LFA and the GT86, they are lightweight cars unlike the 6 Series. Toyota will never accept that for its Supra. I would say the Supra should be based on a CF version of the next Z5/Z5 on which BMW wants to build its M-Two. Again everything depends on what do both BMW and Toyota want to achieve ? Do they want to win races thanks to "Monster" power like the F12 and Aventador, or do they want to win thanks ot power-to-weight ratio ? In this case +400 PS would be enough in a -1200 kg car. Last edited by BMW269; 07-03-2012 at 02:43 AM.. |
07-03-2012, 12:53 PM | #607 |
Rep 1,456
Drives: 2008 E92 335i
Imma check out the FR-S today. Hooman Toyota in Long Beach is offering free oil changes and tires for life.
07-03-2012, 06:49 PM | #608 |
Rep 1,247
This reminded me of the reason why BMW made such an impression on me (thanks to whoever brought it to my attention)... and NO, the E30 M3 is NOT and NEVER was overrated... It's simply the best and the best looking BMW EVER . Now, that's driving FUN:
07-04-2012, 06:43 AM | #609 |
Rep 1,247
I'm sorry but I've let myself get carried away by sweet memories...
07-04-2012, 08:22 AM | #610 |
Rep 340
07-04-2012, 08:33 AM | #611 |
Rep 1,247
07-06-2012, 06:52 AM | #616 |
Rep 1,247
RWD vs AWD ... Old Technology vs New Technology... so, where does the driving FUN lay?
