03-22-2015, 04:20 PM | #1 |
Rep 237
Drives: 2003 Z4 3.0i, 2033 X5
Valve Cover Bolt Leak
Guys,
I have a small oil leak coming from a bolt securing the valve cover. I've attached pictures for reference. Would replacing the bolt solve the problem or am I looking at something a bit more detailed? I did have the valve cover gasket replaced about 20,000 miles ago (14 months). Any feedback would be greatly appreciated.
03-22-2015, 04:40 PM | #2 |
Rep 2,703
See if you can cinch down that bolt a little to see if that stops the dribble.There is a rubber washer under there that may need a little more crush.
While you are at it try the rest of them , there are 15 I believe.
03-22-2015, 04:44 PM | #3 |
Rep 106
If you just replaced the valve cover gasket, I would try taking that bolt out and replacing it first. Pretty cheap check. It looks like you have the M54 engine, so I'm not sure of all the issues, but the N52 has Al one-time use bolts that snap pretty easily. You don't have that situation, I guess, but try removing and replacing and see what happens.
03-22-2015, 06:49 PM | #4 | ||
Rep 237
Thanks for the suggestion! Quote:
Thanks for the input.
