10-29-2017, 03:44 PM | #1 |
Rep 27
Can this top be restored ?
Recently purchased low mile M roadster, Paint is great, drivetrain so far is great
Interior and the top condition is below par. I assume PO left the car topdown parked outside for weeks and months. Pillar& back leather trims are shrunk. My main concern is the what looks like top mildews and molds. I gave it a RaggTopp clean treatment yesterday with no real differences. Orederd a 303 cleaner today hoping it will work. O yeah, the top motor is inop as well which I plan to tackle later on. Can this top be saved? Does it need some kind of fabric paints? |
10-29-2017, 04:18 PM | #2 |
10847
Rep 4,892
Try soft soap (you know, the old fashioned jelly blubber that comes in a tub) and a firm brush. Thats probably the strongest you should use.
And cleaning is best done with warm water, so wet with warm water (not really hot), brush with soft soap and clean of with warm water. If you have a shopvac that can also suck water, you can use that with an upholstry mouthpiece to suck out the soap+molds: (still rinse with plenty of water afterwards) As for colouring you can also try a dye, maybe in a spray bottle, and then rinsing it off. Dyeing also best done with warm water (opens up the fibres). A dye is just a colour that soaks into the fibres, whereas a 'paint' forms a layer around the fabric. A dye cant flake off over time imho. But there are also special fabric paint spray cans (no experience though with both of them) Also check if your draincanals are still unclogged or you'll be buying a new roof motor pump in a few months. The pump is located in a reservoir of the draincanals, so if there's standing water, in will ingress into the pump motor. The outlet of the drains are located near the rear wheels (search the forum)
apexhittinbull17.50 |
10-29-2017, 09:46 PM | #3 |
Rep 27
Some use diluted bleach to soak and use 303 or soap applying 303 afterward.
Think I might try this Brit restorer if thorough cleaning does not work. http://www.renovointernational.com/p...op-reviver.php Wish I got a shop vac but warm water is avail hence I'll try that. Thank you, Mr. Van GuiDoK |
StickMon636.00 |
11-07-2017, 10:17 AM | #6 |
Rep 4,057
Looks like buddy is using the same goop on his hair too.
Huz-Z
11-07-2017, 06:31 PM | #8 |
Rep 27
hahaha
but yeah the link for the youtube clip is the product I'm considering Renovo reviver. Bit hesitant as I already spent $$$ on RaggTopp and Aerosol but guess I'll have to shell out again. |
01-26-2018, 06:38 AM | #9 |
Rep 3
Raggtop
I have not tried to restore yet but I have heard different stories for
Forever Black FB813 which is fairly inexpensive. Renovo seems to be the product of choice for BMW fans, but is a bit more expensive. Replacing the top I was told for my 2003 would be over $2000, not sure I want to spend that and not sure I would want to tackle the replacement myself. |
Tags |
fabric top, mildew, molds |
