      01-28-2018, 10:49 AM   #1
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Undercarriage Cleaning
Do any of you guys ever clean the undercarriage of your Z4, and by cleaning, I don't mean just hitting it with a pressure sprayer or driving through a touchless carwash with an underbody sprayer. I've heard of folks using degreasers, kerosene, etc. Anyone have any real world experience?
Thanks!
Salty
      01-29-2018, 05:35 PM   #2
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Purple power, simple green and wd40...diesel works well too if you want to let parts soak in it
      01-29-2018, 06:51 PM   #3
Steeler
Steeler's Avatar
2428
My car is on stands all winter and so I almost always get under there to check for any leaks etc.
Invariably I find somewhere that looks dirty and get out the simple green and clean.
I always clean the fender liners and armour all them
I have put so much time and effort into suspension and things that you can’t see I want to keep them looking as fresh as possible.
For really greasy areas diesel is a great cleaner.
Pride of ownership is a great thing
      01-30-2018, 10:23 AM   #4
polar
polar's Avatar
Sweden
53
Drives: Z4MC07
I’ve used Orange Degreaser followed by Bare Bones with good results. All from Chemical Guys.
On some caked on oil I used Metal Parts Cleaner from Castrol.
The only thing under there I cant make look good is the aluminium bits. Do you have any tips?
      01-30-2018, 11:23 AM   #5
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Spray diesel saturating the part or let it soak in a tub of it and it'll come out looking new
