10-14-2017, 05:14 PM | #1 |
Rep 52
DRL lights
I have read in the manual that there is an option for such kind of lights in my zed. I need some kind of coding? I want the inner ring to lights up when I switch to auto, because when NOW I switch to auto at 1 am on a sunny day, my lights are completly off.
10-17-2017, 12:41 PM | #3 | |
Rep 52
I need inner rings to join in as DRLs, like for example leds in early Audis. I need lights 24/7 by law, but I do not want my D2S to be on when it is 13 am. Just inner rings I think you can call them DRLs. Am I right in this? Same as you put switch into parking lamps? I guess? |
10-17-2017, 01:02 PM | #5 |
Rep 912
The programming is more like you can choose to activate or not activate the default options that BMW provides within the coding...and that still may not work.
For example, I wanted my fogs as DRL (since I don't have halos). The coding went like this (as an example): Highbeams DRL -not active Lowbeams DRL -not active Foglights DRL -active Which should have worked, but didn't I had no DRLs. So you'd have to get in there and play around which would take some time between loading up one change at a time and seeing if it works. You'd have to pull the module data first to even see if what you want is an option. Hope that helps! . . . . (for a couple hundred bux and you coming to Canada I'd giver a shot hehe). |
