      06-23-2009, 12:10 PM   #23
Motionblurrr
Motionblurrr's Avatar
Drives: Lexus IS300 *sold*
welp, I ordered a Xentec 4300K HID kit. Wish me luck lol
      06-25-2009, 01:54 PM   #24
nvs
nvs's Avatar
Drives: 2003 Z4 3.0i
Wishing you luck.. I'm on the fence on this. I too want HID bad. I've priced OEM HID headlights and they run about $1k each, and that does not include electronics. I haven't found any HID headlights on ebay either.
I did notice that the standard halogen bulb output does have a nice cutoff. SO in theory the HID would too. I'm just concerned about how well the stock headlight will output the HID beam, I don't want to blind other drivers.
For the others that did install after market HID's:
Bimmerman's install guide shows you have to drill a hole into the center of each of the rear cover of lamp housings with a hole cutter... did any of you do this? I'm just hesitant of cutting into my stock housings.
Bimmerman - $170
DTM - $65
Mtec - $300 obo
Hmmmm.....
      06-25-2009, 02:33 PM   #25
RV8tor
Drives: 2006 Z4 3.0i Titanium/Black
The thing about the $300 MTEC solution is that it is truly 'plug-and-play'. Yes, there is additional installation work to mount the electronics, but that is minor compared to some other kits.
      06-25-2009, 03:02 PM   #26
nvs
nvs's Avatar
Thanks for that info. Are you using this system by chance?
Mounting the ballast behind the bumper is fine. I can handle that.. I'd just prefer not cutting up my stock components.
      06-26-2009, 09:02 AM   #27
RV8tor
That is why I bought it. No re-inventing of the wheel. Hardest part is getting to the existing bulb. If you can, put the car on a lift and remove the tire. It almost becomes easy. All the cables and connectors fit. Yes, there are cheaper alternatives, but they all take more labor. It's a trade off. I'm a believer in 'do it right the first time' so I don't have to do it again. I researched HID conversions for about a month before I bought the MTEC.
