      08-31-2013, 12:57 PM   #309
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Thanks Woots. The transparancy is appreciated!
How does it sound like between 2500-4500?
      08-31-2013, 01:29 PM   #310
Woots
Woots's Avatar
Drives: Z4///M Roadster
Below 2800 it sounds reasonably tame, which is ideal as I don't want to wake the dead when I'm trundling along
But between 3000-4500 it really growls
And then at higher revs it just screams at you
It's got quite an organic vocal range in that it changes character throughout the rev range, really need to get hold of a go pro...
      08-31-2013, 01:39 PM   #311
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Sounds awesome!
Below 2800, is it not noticeable or does it sound like a very conservative growl, like having a gruppe m on there or something?
      08-31-2013, 01:40 PM   #312
dazed^
dazed^'s Avatar
Netherlands
Drives: '07 Z4 M Roadster
But the idle hunting causes the Hill Assist function to stop working?
      08-31-2013, 02:02 PM   #313
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by Woots View Post
I emailed sal earlier but thought I'd just post my observation up now, just to ensure there is absolute transparency and then you guys aren't left in the dark...hopefully with honesty in whatever I put up on here you guys will feel better about getting one of these
Anyway, the cold idle, yeah with brake applied it does hunt with brakes applied but it only does it while the idle sits at 1100rpm, after a minute the idle drops to 900 and then the hunting is vanished. While the revs are at the 1100 idle it does sound more throaty and pops a bit more than normal, and does smell quite fuel rich, not really an issue just an observation...might be something that's perfectly fine or it may be something evolve decide to get rid of in the revised maps in the coming future.
I'm pretty sure there are more lift off pops now though, and it sounds awesome above 6000rpm
At 7500 it's so loud that a bit if trim on the passenger a pillar sometimes vibrates
Awesome!!
Does the hunting vanish after about 30-60 seconds following a startup? The car starts in an open loop mode because the oxygen sensors aren't warmed up. Prior to them warming up, they will give inaccurate readings and are ignored by the ECU. The car should run rich at this stage to be on the safe side. Obviously there's "too rich", but "rich" is normal.
      08-31-2013, 02:03 PM   #314
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
If I remember correctly, hill assist disengages on clutch engagement and not throttle. If I'm correct, it wouldn't have any noticeable effect in that regard.
      08-31-2013, 02:06 PM   #315
Woots
Woots's Avatar
Originally Posted by Devious21 View Post
Sounds awesome!
Well I got used to the afe intake which growled more than stock, I would say it's 'slightly' more aggressive than afe below 2500 rpm, the mrs didn't really notice or comment on it when I take her to work and with her in car I drive extremely conservatively as if I'm on a driving test (a British one not an easy American one) so that's good, at least for me
I wanted something that when I'm taking my gran home she isn't in tears or haemorrhaging, but then on the way home I can release hell
      08-31-2013, 02:08 PM   #316
Woots
Woots's Avatar
If I remember correctly, his assist disengages on clutch engagement and not throttle. If I'm correct, it wouldn't have any noticeable effect in that regard.
I'm not sure about hill assist, as to activate it on cold start I'd need to apply the brake first to then hold it...and I don't want to press the brake as it bounces the revs...if that makes sense? So I can't use hill assist straight away
      08-31-2013, 02:10 PM   #317
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
sounds great. Thanks for all the detail!
      08-31-2013, 02:10 PM   #318
Woots
Woots's Avatar
Yeah after 60ish seconds the revs drop to 900rpm at idle, I'd say it's about that time that the hunting disappears
Personally I like the noise it makes on start up (ignoring the bouncing brake rpm) it really sounds quite mean when it's bubbling and spitting away...and the smell just seems more 'Motorsport'
      08-31-2013, 02:12 PM   #319
Woots
Woots's Avatar
I could do with a second opinion from an outside party really so thru can say what they think
Planning on seeing Byron very soon so I'm sure he will have some words to say, and as I'm an aircraft engineer and he is a trained mechanic (as well as a trainee sex pest) so I'm sure we can put some words together
      08-31-2013, 05:03 PM   #320
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      08-31-2013, 05:04 PM   #321
Woots
Woots's Avatar
Originally Posted by bignosejim View Post
I'm not sure if that's good or bad?
      08-31-2013, 05:12 PM   #322
bignosejim
bignosejim's Avatar
Not bad, just didn't expect it in this thread. Thought it deserved a funny response.
      09-10-2013, 04:12 AM   #323
Imran@Evolve
Imran@Evolve's Avatar
Drives: All of them
Sorry for the delay on these. Still moving everything over to the new workshop so the dyno is still in our old workshop.
Wheel Horse Power
Flywheel Horse Power
      09-10-2013, 07:44 AM   #324
avsbmw
Drives: 07 Z4MC
wow those are impressive graphs
      09-12-2013, 03:13 AM   #325
Woots
Woots's Avatar
Think we still need vids
I'm gonna try and make some soon
      09-12-2013, 05:00 AM   #326
Imran@Evolve
Drives: All of them
BT still haven't sorted our fibre optic out so can't even send my video files to my editing guy. Think I will just send them via snail mail instead!
      09-14-2013, 12:04 PM   #327
Woots
Woots's Avatar
Silver grey ///MR, Evolve CSL carbon fibre intake
An ///m is like ke$ha....she will take you to a club, snort something illegal, f**k you in a VIP booth, get you thrown out and then arrested....
      09-14-2013, 12:27 PM   #328
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
WANT
      09-14-2013, 02:29 PM   #329
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Looking good, Woots. Just placed my order this past week. Went with the high gloss finish, looks like yours is the Matt finish?
      09-14-2013, 02:32 PM   #330
Woots
Woots's Avatar
Awesome mate, looking forward to seeing how you get on with it
When are you expecting delivery? Yeah mine is raw carbon, not sure if it differs from the matt finish or if they are the same? I guess mines just straight out of the oven..
