      06-30-2012, 08:05 PM   #1
GammaZeta
Drives: 1
What is "drone" ???
As a new Z4M member looking to buy an aftermarket exhaust, I keep reading about "drone". Can someone explain to me what drone is, what it sounds like, how it affects your hearing, etc.?
      06-30-2012, 09:47 PM   #2
DataStream18
Drives: 2003 ESS TS1 Z4
Just what the name sounds like when you say it. Elongate the word when you say it, meaning stretch the word out. Its annoying to some but other it doesnt bother em'.
Love is like a fart; if you have to force it, it's probably shit.
      06-30-2012, 10:10 PM   #3
GammaZeta
Drives: 1
I'm familiar with the definition, but when applied to the Z4M. Is it a constant noise? Or does it only happen in a certain gear or rpm?
      06-30-2012, 11:33 PM   #4
seank
enthusiast
seank's Avatar
48
I believe it only applies to certain rpms. If it's all the time, they just call it LOUD. It is usually loudest at the power band or just before.
I also had never heard of this before I came to this site.
      07-01-2012, 12:04 AM   #5
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
It's not synonymous with "resonate" but it's close. If an exhaust drones, it constantly makes noise, usually when you don't want to. It's a descriptor for undesired noise on the highway at lower rpm. It's the opposite of quiet cruising. There's not an exact sound that is drone. Diablo drone is different from Magnaflow drone, which are both different from RPI drone.
Certain frequencies will resonate through an exhaust at specific rpm. Others will be canceled out. The exhaust can be designed to enhance or minimize particular frequencies. With testing, one could figure out which frequencies are considered desirable and which are not, and then design the muffler to cancel the unwanted frequencies. However, as the engine moves up in rpm the frequencies emitted change. The muffler that canceled a 40 Hz wave may allow a 60 Hz wave to be amplified... so now the muffler that was tolerable at 2000 rpm may be obnoxious at 2500 rpm. If you want an exhaust that is quiet during cruising, you give up some song at the high rpm.
Then there are octaves and resonating frequencies for the vehicle itself... but honestly, I'd expect most muffler companies to make one good design and adapt it to all models with minimal changes. They probably bolt it up to make sure it doesn't sound like crap, make some tweaks, and then call it good. This is just me guessing though, because it's fiscally impractical to pump out more than a few prototypes.
I'd assume Shipkiller knows quite a bit more than I do about wave propagation .
