03-05-2014, 08:09 PM | #1 |
Rep 279
Spring Maintenance!
Just replaced my front wheel bearings, RTABs, upper and lower rear ball joints. Had a bit of wiggle from my front right wheel that could be felt in the steering wheel and was driving me nuts! Also, the rear end was feeling a bit floaty and unstable in turns. Took me about five hours at a relaxed pace, pitcher of ice tea and some tunes. SOOO much betta!!! Less noise, vibration and slop. I already had parts on hand but somebody needs to try these out and report back:
http://store.bimmerworld.com/bimmerw...kit-p2138.aspx Beer thirty!
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
03-05-2014, 09:16 PM | #3 |
Rep 279
Yeah....Stock RTABs are about $37 a set from autohausaz. I run the stock bushings with limiters and they are "OK". I've installed two sets since I've had the car(40K+ miles). It would be worth it to me if the Bimmerworld ones were an improvement over stock performance wise and had better longevity. Maybe after my current RTAB's wear out I'll give these a try.
03-06-2014, 07:33 AM | #5 | |
Mechanical Engineer
96
Rep 1,025
03-06-2014, 08:57 AM | #6 |
Rep 279
Thank you. And yes, Gudrenn does love me!
03-06-2014, 09:15 AM | #7 | |
Rep 279
Not as bad as sub-frame bushings as you don't need to disassemble much to get to them. Actually pretty easy with a bushing press tool like the MIS one I have. Performance and longevity would have to be a lot better to make them worth it. Less dynamic toe change mid-corner is a good thing in my book.
03-10-2014, 04:32 AM | #8 |
1621
Rep 4,294
Lol Gudrenn...
What's next on the menu? Cheers I did a similar maint last winter, but should have gone with the rtab limiters.. Easy install if your doing it anyways..
Powered by |
03-10-2014, 05:46 AM | #9 |
Rep 2,138
Drives: Me
I have had these installed for that last two years:
http://store.bimmerworld.com/powerfl...px?Thread=True Just remember, the RTAB's do not do anything for ride quality but for thrust alignment during acceleration. |
03-11-2014, 04:43 PM | #10 | |
Rep 279
Thanks Ship! I think I might give those a try here soon. I ordered the Superflex urethane FCAB's so I might as well give urethane a try on the trailing arms
03-12-2014, 09:38 AM | #11 |
Mechanical Engineer
96
Rep 1,025
just noticed you did all that in 5 hours? mind blown.
do you own the BMW specialty tools for every one of those jobs? i don't think i could do both wheel bearings in 5 hours alone, let alone that whole list. |
03-12-2014, 12:14 PM | #12 | |
Rep 2,138
Drives: Me
Are they offset like OEM to give you more caster? |
03-12-2014, 02:09 PM | #13 | |
Rep 11,667
Yes they are offset.
03-12-2014, 05:27 PM | #14 |
Rep 2,138
Drives: Me
Ian, that looks like a picture of my FCAB's and I have the Whiteline's. I thought you had the Powerflex FCABs?
Are the Powerflex and Superflex the same? Now I am very confused. |
03-12-2014, 06:58 PM | #15 | |
Rep 279
I do have the Koch kit specifically for the ball joints and RTABs, and MIS RTAB tool also which I prefer for that job. I used to make my own tools with all-thread and pipe caps but I broke down and got specialty tools when I had an e46 as I had little spare time then. TOTAL BREEZE with the right tools! I have been using the same method for the front wheel bearings for about fifteen years. Brake the axle nut loose, loosen lug nuts, put car up, remove wheel, remove caliper, carrier, rotor. Mount wheel back to hub, finger tight lugs and wiggle wheel fore and aft gently pulling towards you. Bearing usually comes right of with no fuss. Drivers side bearing/hub came off in 2-3 wiggles, passenger side came off by hand! It wasn't total toast, but it wasn't healthy! So worth it. Car/steering is tight again.
03-12-2014, 07:03 PM | #16 |
Rep 279
He's got the Superflex FCAB's as it was his post's about them that made my mind up to order them. They are offset, which the PowerFlex ones are not. Have not installed them yet. Probably not until summer as mine are fine for now and I go back to sea this week for two months.
03-12-2014, 07:06 PM | #17 |
Rep 2,138
Drives: Me
03-12-2014, 07:28 PM | #18 |
Rep 279
Oh, nothing as noble as your gig. I'm Merchant Marine and spend most of my time with the fishing fleet in the Bearing Sea. I will be relieving the mate who's been up there for awhile and I'll finish out the Pollock season. Then I'll change hats and be the engineer for a mini ship yard. YAY.....
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intakeLast edited by mtrhed; 03-12-2014 at 07:29 PM.. Reason: spell check! |
03-12-2014, 07:32 PM | #19 |
Rep 2,138
Drives: Me
I have spent a lot of time in the Bearing Sea (under it).... As for being noble, people who brave that weather to feed others are noble as hell....
03-12-2014, 07:44 PM | #20 |
Rep 279
Why thank you Sir! It's a job I enjoy 99% of the time and we do help feed the world. Chicks dig it too!
03-13-2014, 09:09 AM | #21 | |
Mechanical Engineer
96
Rep 1,025
Could you give me a link to the Koch kit you mentioned? |
03-13-2014, 03:17 PM | #22 |
Rep 279
I found my set on EBAY years ago. I believe they can still be found there. Or here: http://www.kochtools.com/. Makes the job very easy, can be done on car. I just unbolted bottom of shock and rear caliper for the upper and lower rear ball joints.
